Well guys, in my opinion the jury is still out on scoop opening sizes. I have tried several different sizes and designs with varying results. I run a 302 cu in motor and we are inching toward 250 MPH. At present I run a Harwood scoop that has about 35 sq. inches of opening. The car performs well and the scoop pressures are running 0.0 to 1.0 inches of water less than the pressure on the front of the car. The EGTs are normally within 50 degrees of each other, so I don't think that turbulence is a problem. At top rpm is the greatest difference. The engine still wants more air than is being delivered by the scoop. In 2001, I ran an opening of 5 sq. inches and the scoop reading reached the lower limit of the pressure (-9.6" H2O) measuring device by 6000 rpm and returned to 0.0 when the engine was shut down. At the Lakes in November 2001, on the 3rd run, I cut the nose of that scoop off, giving me about 25 sq. inches of opening starting at hood level, and we got the first positive numbers (0.6" H2O at the top of high gear).
Having said all this, I do not argue with the engineering of the opening. But, there are just too many variables involved to make a flat statement about scoop sizes. I don't think that you want to argue that we are not posting some good numbers with 35 sq. inches of opening. Anyway, I am not through experimenting. I still want to see a pound or two of positive pressure. I believe that one of our problems is getting clean air to the scoop, I have a plan for next year to help correct that. The picture of the Stude is a good example of putting the opening in clean air. Our opening is only about 2 inches off the hood.
The bottom line is...you have to start somewhere. What works for me may not work for you. I have found that to be true throughout my racing career. There is a proverb that I keep in my mind "A person who walks in another's tracks leaves no footprints".
