Well, CatMan, If you plan on running that Roadtrain, Law #1 is out the window. If you plan on running something a few tons lighter, you will find the faster you go, the less traction you have ( do to aero lift, amongst other things), and adding weight is not nearly as much of a handicap as aero drag. The bottom line is, you gotta have traction to go fast, and with the Roadtrain, I forsee no problem with that particullar item.............
