I got my new airbox and air ducts from Kent at Airtech and have started the installation process. Looking at my stock box and my stock ducts this should provide a lot more air.
My injectors have been cleaned and calibrated. I had one injector that had a "fair" pattern and was flowing a low volume of fuel. The other three were good, all are now excellent.
Stacks installed
My plan for a fuel tank
The plan in sheet metal
I do not have any tool to bend sheet metal so I cut small grooves where I wanted the bends.
Here is the bottom part of the fuel tank
And the top, it will be a two piece tank
I made four holes with a one inch holesaw and then used a die grinder to complete the job for the filler neck.
Here is the tank with the filler neck welded in. I will wait to weld the rest of the tank until later this week after the rest of my fuel bungs show up.
Here is the tank on the bike
Tank and airbox
