I got the following gear ratios from another site:
Gear ratios for the A340E 92 SC400 US model are
1st 2.804
2nd 1.531
3rd 1.0
4th 0.705
Rev 2.393
That is actually a pretty wide ratio transmission with a strong overdrive gear. Think how hard it is to pull overdrive on a big hill. According to Costella, and I agree, "Bonneville can be like pulling a big hill". So if you gear the car higher in the rear than you would on the highway what is going to happen when it shifts into 4th. If it is like my truck it will fall on it's face.
Some of the 5/6 speed manual overdrives only have about a 20% drop going into 5th and/or 6th. Much better. I see that GM/Chrysler have developed a 6 speed automatic jointly that will be coming out in future models.
Still like mentioned above it is going to take more HP to turn the auto vs. the manual, so why give that HP up especially if you are pursuing a record.
I guess is there a reason that for you the automatic is desirable?
c ya, Sum
