OK, here goes-
1928 Dodge Roadster V4F/STR #60. New car. Total of 6 trips down the salt the year.
Weight 2393 # with driver. 53.1 % rear weight distribution. No ballast.
Car was traveling 117 mph (according to the GPS) just before the 2 mile and it just, literally, turned around. I could definitely feel the wind causing the car to wander, but it literally, just turned around. It was not an overcorrection... as I didn't even have time to correct. Again, it just turned around. Conditions at time of spin. Big wind. About 29 mph. I was the last run before they shut it down for the day because of the wind.
But, that being said, the car was a handful every run before. The rear end seemed to want to hop from side to side. After discussing this with Ron Joliffe in impound he suggested more rear tire (Goodyear Front Runner 27 X 4.5) pressure (was 45 psi). I did increase it to 60 psi for my return run, and it did seem to help the hula dance a bit, but it did not eliminate it. FYI- have a background in sports car racing, autocross and hill climbing so I have a pretty good understanding of vehicle dynamics, but I have never experienced such instantaneous, abrupt oversteer as I did on the last run of the week (the one where I got the sticker from Lee Kennedy!). Kind of an embarrassing way to start your landspeed career.
Since returning, I have done the following-
Checked the rear suspension. Ford 9" (Currie) Rear axle is square in the chassis. No bind. I have about 1 1/2 in travel in compression but very little in rebound (had to jack the coilovers up at the last second to add the fenders for STR. Wondering if this zero rebound situation "lifted' the rear end. I have ordered new coilovers to allow for more rebound.
Front end. Solid front axle. 6" drop. All new components. Transverse spring 1/16 inch toe in. 9 degrees caster. Chassis mounted rack, but negligible bump steer. No front panhard. 1 1/2 compression, plenty of rebound. No bind. 15 X 4" wheels 1 3/4 back space. 4" scrub radius.
I've read every posting I could find on suspension since (hindsight...) and based on what I read, this week I changed steering arms to greatly reduce Ackerman, added a dead perch to eliminate any shackle deflection, and added another 1/16 inch toe in (total 1/8).
Any suggestions are greatly appreciated!
Thanks, Pedro
