I am familiar with a Bonneville STR class '27 Ford/ 32 Chassis w/ a small block V8. The roadster had a nasty habit of spinning above 170mph
. Here are some of my observations, thoughts & ideas regarding this racecar.
The trunk was completely filled with a water tank, fuel tank, 3 batteries and lead ballast. The ballast & batteries were over or aft the rear axle.
The front suspension was an off-the-shelf aftermarket street rod traverse leaf sold axle. Most street rod steering arms are designed to provide front tire clearance resulting in a negative Ackerman. About 20 degrees caster. Scrub radius unknown.
The required rear fenders had been trimmed/shortened on the front edge.
Besides using a body that was designed for 50 mph tops, IMHO several other problems contributed to the tendency to spin.
• The CP was forward of the CG.
• Too much added weight aft of the rear axle.
• Negative Ackerman caused outside front tire to skid.
• Open rear end
Possible fixes:
- Mount a Moon style water tank in front of the grille.
- One battery
- No added weight behind the rear axle
- Locked rear end.
- Go to a no Ackerman setup.
- Extend the front of the rear fender down to the original stock shape/position
These are my observations and ideas. Please criticize, suggest, correct, ignore, etc....
