Author Topic: nitrous on a motorcycle  (Read 14563 times)
Offline BVCBR
  • Pflum & Wagner Racing
    • Gotfastbikes.com
Re: nitrous on a motorcycle
« Reply #45 on: May 10, 2010, 07:57:28 PM »
Edelbrock, and I'm sure all other Nitrous companies, offer blank jets. You can drill them to any size you like. The Edelbrock part number is 73013 for Taper Face Jets and 74000 for Funnel Jets.
JW
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
Offline agrassfidf
« Reply #46 on: May 12, 2010, 11:36:14 PM »
Does running nitrous put you in a different class/category?
Offline Cajun Kid
« Reply #47 on: May 12, 2010, 11:40:24 PM »
YES.. anything "other than" GAS bought from the track vendor puts you in FUEL Class..
So adding Nitrous puts you in Fuel class no matter what else is in your tank.
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline Constant Kinetics
  • I'm not Crazy, I'm Invincible!
    • Constant Kinetics
« Reply #48 on: July 19, 2010, 07:12:20 PM »
The engine likes timing .The more I advance the timing the more fuel it burns and the more power it seems to make
You need to find a way to retard your timing when you spray or that will be the last run that engine is likely to make. It sucks that MSD can't read your ignition unit because they make one that comes on automatically when you spray, but they aren't the only ones who do.
Wierd is good
Offline 1212FBGS
    • http://www.motobody.com
« Reply #49 on: July 19, 2010, 07:22:36 PM »
no not really.... if yer spraying less than a 50 shot there is no need to retard timing..... but some people like me think spraying anything less than a hun is a waste of time. :-o
kent
Offline racer x
  • Dark Horse Racing 10-B
« Reply #50 on: July 19, 2010, 07:58:23 PM »
I have an ignition system called a BRT-Tis . I have a switch on the bar. I can select between two maps on the fly. When I make an all motor run I have close to 43 deg of timing across most of the RPM band.
When I spray nitrous I will start with 35 deg across the entire RPM range ( stock ignition curve ) and work from there.
« Last Edit: July 20, 2010, 06:34:06 AM by racer x »
Offline Vishnuatepork
« Reply #51 on: July 20, 2010, 02:48:01 AM »
http://www.ignitech.cz/english/aindex.htm
Have you tried these guys for an ignition unit?
I have one, not installed yet, about 150USD I think
Cheers
Alan
Offline racer x
« Reply #52 on: July 20, 2010, 06:32:55 AM »
Thanks for the link . I will look at that.
The BRT is made just for the 250 it is a fully programmable unit and has two maps that can be switched on the fly or with a relay when I spray.
It has a programmable rev limit up to 16000 rpm and the ignition curves are programmable in 16 steps.
In case anyone wants one It is available from Spoptisimotousa
http://www.youtube.com/watch?v=d2GvsiRa7E8
« Last Edit: July 20, 2010, 06:34:39 AM by racer x »
