willie , the DLRA M/C tech committee has made mandatory some of the suggestions made here , all riders must wear a back protector , and any riders riding in classes which exceed 200mph full body armor ,we allow either the all cow leathers or standard racing leathers ,with any leathers having perforations the rider must wear an under garment of suitable fire retardant material .
We have only had 2 M/C accidents ,in both cases the riders suffered broken bones , shoulder/collar bone ,both the result of the fall from the bike and contactwith the salt , inspection of the leathers after ward revealed only minor scuff damage and a small rip in one set possibly from contact with some part of the bike during the fall ,all stitching was undamaged as was the zip on the one two piece , the helmets also showed scuff damage ,but other wise remained in tact ,the crush zone material was an unknown ,both helmets were retired from further use ,the most likely causes for the crashes were, bike one Yamaha R1 ,was using a narrow section front tyre on the rear ,valve stem was missing tyre was destroyed , we concluded the cause most likely broken valve stem caused rapid deflation of rear tyre and crash , we instituted all metal valve stems mandatory and banning of the use of front tyres as rear drive tyres , bike 2 a one off vintage Vincent black lightning ,talking with the rider , an uncontrolled tank slapper was the most likely cause , we instituted the banning of the old friction type dampers and the use of a modern style steering damper on all motorcycles regardless of class , these crashes also ushered in the mandatory use of back protectors and full body armor .
Jason I'm not convinced that 2 piece race suites should be banned ,do you have any proof that they separate in crashes ( on salt surfaces?) ,but the use of fire rated undergarments should be made mandatory .
Rider parachutes are worth investigating as are chutes for the M/c as well , but from our limited data the actual fall from the bike at speed and making contact with the salt surface seems to be the major cause of injury
cheers
Gary
