The guys at Reher-Morrison, a pro stock engine builder co of some renown say for your engine size, pick your block, pick your crank, design your pistons (ring package, pin size, location, CH you want, (low so piston light) deck height etc, etc and then measure all and pick the rod that connects all together. Forget the ratio. there are some suggested limits though. A couple posts, one by Larry Meaux of Meaux racing heads and one by Darin Morgan, chief of cylinder head reasearch at Reher Morrison have some insight in addition to that already posted.
By Larry Meaux
from experience Dyno testing various
Engine sizes and Rod Ratios
the trend so far shows
increased BlowBy CFM (6 to 8 CFM) as you go less than 1.50 Rod Ratio
if you can't run a Vac-Pump, i'd keep Rod Ratio above 1.50
and with 1.43 Rod Ratio with same Hone finish
8 to 10+ CFM BlowBy, but thats not much of a problem
with a Vac-Pump ...the higher piston speeds and shorter rod ratios,
are showing more HP/TQ per 1 CFM of Cylinder Head Flow up to a point.
usually 1.60 to 1.65+ you'll have no major ring BlowBy problems
and 1.6 to 2.0 can show 1.5 to 4 cfm BlowBy range
if you have a very good Block , (Correct Hardness and Thick Walls),
the BlowBy CFM numbers will be reduced from the above numbers
_________________
Meaux Racing Heads
__________________________________________________
Once again, what maxracesoftware said is right on the money. The piston rock and side loading become a big factor below 1.50 with piston speeds over 4500ft/min. If its a low rpm street machine that never sees the high side of 6000rpm or 4000ft/min, then the problems with blowby are much less but none the less still present. When I discuss Rod Ratio I always dismiss people who think there is an " ideal" rod ratio and are willing to compromise the overall engine design in order to achieve this " ideal" Rod ratio. I have never said that there are not both high and low limits one must avoid. A Rod ratio of 2.2:1 or a 1.4:1 is not going to help matters any. Anywhere between 1.65 and .1.85 is fine. any less and you run into high skirt loading, blow by and frictional HP losses. Anything above 2:1 and you run into pressure lag and have to run the cross sectional area of the ports very small and maintain a higher mean velocity in order to help make up for it.The little 265 and 302 Comp eliminator engines are usually a case study in pressure lag unless they run the Aurora block with a 8.5 deck and get there ratio into the 1.8 range.
_________________
Darin Morgan
R&D-Cylinder Head Dept.
Reher-Morrison Racing Engines
My bigger concern with this engine is not the rod ratio, which unless you are using one of the specia low deck (8.5") blocks is in the 2.3:1 range and nothing really you can co about it since as Dave Dahlgren already said your CH is in the 1.75 range. More ( a lot more) if you shorten the rod to give a more "ideal " ratio. Makes a piston weigh a ton and pin too far down.
To me the problen is the heads. The ports may flow well for good power but be slow. You need to think much smaller/faster flowing ports (but of course still with the cfm to make the power) and this may be tough to do. Porperly designed, ported etc should do it. The other thing is the chamber. Putting a 18cc dome in a 66 cc head only gets you to a net of about 56 after accounting for gasket only, let alone quench, deck clearance, valve pockets etc. You need something in the low 40's or better to start with to get rid of the dome as much as possible for not only more compression as noted above posts, but also for flame travel etc and get the piston out of the head as much as possible. Look at something like the Chevy 15* head that starts at35-37 cc and can be milled more. Other heads may but I think you need a smaller chamber.
IMHO
Jack
<small>[ February 10, 2005, 03:57 PM: Message edited by: Jack Iliff ]</small>
