Author Topic: Caster and camber  (Read 6050 times)
Offline Tzoom
  • All revved up with no place to go - Meatloaf 1977
Caster and camber
« on: July 05, 2008, 01:10:13 AM »
What caster and camber (king pin angle?) to you use on a straight front axle?
Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games --- Ernest Hemingway
Offline interested bystander
Re: Caster and camber
« Reply #1 on: July 05, 2008, 01:22:34 AM »
Methinks it's deju vue all over again.
Those topics  have been bandied about for at least the last ten days- there a huge amount of information and good opinions in the recent Land Racing archives if you take the time to search.
Good hunting!
5 mph in pit area (clothed)
Offline Tzoom
« Reply #2 on: July 05, 2008, 01:36:38 AM »
I did and I read anywhere from 6 degrees to 30 degrees of caster so I guess I've pretty much nailed that down but I didn't see anything about camber except for Sum's statement that he is "shooting for no camber".
Offline hotschue
« Reply #3 on: July 05, 2008, 07:49:41 AM »
Currently building axle for new car.  13 degrees caster - 0 camber - 0 toe - 0 scrub - should go fairly straight.  13 degrees is a subjective number, whatever works, I raced a few Uyehara funny car chassis and that was Dave's choice, worked for me, f/c spec is as close to running as LSR and it still has some steerability at slow speed.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline Tzoom
« Reply #4 on: July 05, 2008, 08:53:19 AM »
Thanks.  I was looking at photos of funny car/altered axles in a Mark Williams catalog and it looked like they had about 10 or 12 degrees of camber.  Seemed like that would cause a lot of drag.
Offline hotschue
« Reply #5 on: July 05, 2008, 09:06:52 AM »
There is no drag until you turn the steering wheel.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline RidgeRunner
« Reply #6 on: July 05, 2008, 09:09:08 AM »
     Don't forget spindle kingpin inclination - kingpin is NOT 90 degrees to wheel spindle plane - usually about 8 to 10 degrees difference based on original design.
Offline hotschue
« Reply #7 on: July 05, 2008, 09:30:41 AM »
There is another thread in this heading that addresses scrub and king pin angle.  A must read if you are building an axle.  Originally I looked through all the catalogs to buy a finished axle, came to the conclusion build it from scratch to meet your particular needs.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline Tzoom
« Reply #8 on: July 05, 2008, 11:30:35 AM »
Wow! No lack of information on that thread.  I'm going to have to print it out and study it more.  Thanks
« Reply #9 on: July 05, 2008, 06:08:03 PM »
I see how 1/8" tow-in is recommended for "used parts" -- so the slop doesn't result it toe-out.  I think zero is almost unobtainable and would err on the tow-in side -- just to be safe.  Front Runners seem to search at high speed on salt -- our preference is for the grooved tires such as M&Hs.  (Now we're arguing Ford and Chevy . . . )
Offline sheribuchta
« Reply #10 on: July 05, 2008, 08:32:31 PM »
stan is right---one thing though toe is something you can check yourself --jack up the front of the car --spin the tires (front) and mark them around the outside of the tire with a ink pin as close to the center as possible --now let the car down and push it backwards 8 or 10 feet --now push it forward 8 to 10 feet (you did that because the tires try to tow out when the car moves forward) now check the tow by measureing from line to line (wheel to wheel ) in the rear as high as you can (ideal would be half way up the tire --spindle height ) now measure the front (same height ) subtract the front from the rear if you come up with 0 to 1/8 (narrower in front) inch you are good to go --if the front measurement is bigger than the rear you have toe out---not good--make your adjustments and push the car backwards again 8 to 10 feet then forward 8 to 10 feet and check your measurements if there off repeat until they are right on the money pushing the car backward then forward after each adjustment  --you would be suprised how many cars ive checked fresh from the alignment shop and they were off now i always do my own  then i know its done--it is important to have good parts with no play if you dont fix that first--all of the drag race cars we set at 0 toe on dirt or salt i would run 1/8 toe in --im only talking about straight axels here if you have a arms look up the specs for your car --us bike guys dont deal with such things   LOL  willie buchta
