Hello
I have six different front wheel options that will fit into the front end on the bike running in the BUB Modified class.
Before I order the front fender, I need to choose one of the following.....
17" Suzuki Aluminum three spoke mag without brake discs - 4.25 inch wide rim. This is the shortest tire, but also the widest(by far)
18" five spoke mid 1980's yamaha mag - heavy,heavy, heavy wheel with swirly, square spokes, but the rim is only 2.75 wide.
the same 18" five spoke mid 1980's yamaha mag with both brake discs.
18" spoked wheel, 2.75 rim, 6 inch diameter hub surrounded by 6 inches of spokes and rim
18" spoked wheel with both brake discs installed, 2.75 rim, 6 inch diameter hub surrounded by 6 inches of spokes and rim
18" drum wheel, 2.75 rim, 10 inch diameter hub surrounded by 4 inches of spokes and rim
No matter what wheel is used, there will not be any front calipers.
Assuming that the fender is an equal fit for all the wheels, which of the six do you all think would be the best choice? What about the aerodynamics?
Mark
