Author Topic: high performance engine coatings  (Read 4993 times)
Randy Williams
« on: January 29, 2005, 12:59:00 AM »
We have started on our latest engine. The block is machined and ready.Now we want to coat the pistons and are not sure which way to go.Do we just do the tops? Or should we do the skirts too? Any thoughts on doing the combustion chambers and valves.
 Engine  5.9 Cummins Diesel,Boat pistons 14-15:1 commpression after machining. about a 750HP shot of Nitrous   :D   .
 I have done a fair amount of research and it seems most of the coatings are almost all the same. Any leaders in the field?
 Thank's for your input and thoughts,
  Clem Roberts and Randy Williams  No Class Racing
Offline }{ead$hot Zod
    • http://FriedDiesel.blogspot.com
Re: high performance engine coatings
« Reply #1 on: January 29, 2005, 01:50:00 AM »
More of a thought then anything scientific. I heard http://www.swaintech.com was decent. I've done some research for the same motor. Swaintech seems to have coatings for everything under the sun.
 Unfortunately since Consumer Reports hasn't run a "Top Ion Bonding Companies" issue, its hard to compare. Swain has a pretty extensive pricelist. http://www.swaintech.com/price.html The website is a pretty informative.
1992 Dodge D250 Cummins running biodiesel and waste vegetable oil.
#284 ?/DT
"I don't do use drugs but my truck does"
->Stage III Meth injector.
« Reply #2 on: January 29, 2005, 11:51:00 AM »
Hey, Randy & Clem -- it's good to see that the truck project is still alive...especially if it means we'll have another look at the Whoop-Ass pit vehicle, too.
 I'm not much of a coatings expert, but have you been in touch with russ Meeks at Finish Line Coatings?  I dunno if they do your kind of coatings, but -- being in the coating bizness -- maybe they can give you good advice on where to look if they can't do what you want.
 I think they're at www.finishlinecoatings.com
Offline ulrace
« Reply #3 on: January 29, 2005, 01:19:00 PM »
We use Powerkote by techline coatings. They make a thermal barrier, a dry film lubricant for the piston skirts. They also have a coating for the cylinder walls that just rubs on. The other two are baked at the same time. Number is 909 304-0498
 website is:  http://www.techlinecoatings.com/Engine.html vey reasonable and we have seen the skirt coating last for several years..
 bob larimore
Offline joea
« Reply #4 on: January 30, 2005, 02:29:00 PM »
RANDY YOU NEED TO TALK WITH RUSS MEEKS
 AT FINISHLINE COATINGS!!!!!!!!!!!!!!!!!
 Seriously,  he is "our" kind,  he lives
 and breathshotrodding and landspeed racing,
 he races at Bonn. every year........and KNOWS
 coatings................
 Randy, he will take care of you and your needs..
 Joe  :)
Offline DallasV
« Reply #5 on: January 31, 2005, 03:45:00 PM »
you may also want to look at HPC Coatings. They do pretty good work. They do work for us and I know Vescos and Burklands have both used them.
 http://www.hpcoatings.com
Offline turborick
  • Go as fast as we can with as little as we can
    • http://www.bonnevillestreamliner.com
« Reply #6 on: March 16, 2005, 12:27:00 PM »
You should also give Cryogenics a look it has worked for us
 www.nwcryo.com
 Rick
Rick Yacoucci
The new Nebulous Theorem 3.5 #788
Offline LSR Mike
  • First Pass-June 25, 2000; Muroc Dry Lake
    • Mike & Paula's Site
« Reply #7 on: March 16, 2005, 06:01:00 PM »
Calico Coatings...In your neck of the woods also Ex-NASCAR bunch
  http://www.calicocoatings.com
 Coat the skirts with the slick stuff coating.
 and I think it's the tops AND bottoms of the pistons with the heat stuff. don't forget the bearings
  <small>[ March 16, 2005, 05:03 PM: Message edited by: Mike Meierle ]</small>
Mike M.
BNI/ECTA
Offline RichFox
« Reply #8 on: March 17, 2005, 11:29:00 AM »
Some years ago I ran a 270 GMC with Jahns cast pistons and two Corvair turbos. Got to know the "Black Death" very well. I was also working in a plasma spray dept tool room. I don't remember to well, but I used Metco wire, standard bonding ocy/act on the piston tops followed by (I think) Metco 601-cermaic plasma spray and it worked great as a thermal barrer. I did the exhaust housings also. Maybe you have a Metco dealer near you that can recomend a shop?
Offline firemanjim
« Reply #9 on: March 18, 2005, 03:35:00 AM »
I have had good results with these guys
 AM Performance Coatings  call 586/294-4311.
 He has my exhaust system and charge tubes right now.
