Originally posted by Malcolm UK:
The accuracy of timing equipment and the number of decimal places then used to calculate speeds is set down in the rules of the organisations who recognise land speed records.
Nowadays most of the errors are eliminated and do not forget that for many two runs are averaged - whether it is time or speed - and so you go from .001 to .0005 increments of time.
Unfortunately the FIA consider themselves far too important to answer queries from mere members of the public.
I'd missed the point about the average of the two runs muddying the waters. Thanks for pointing that out.
With successive roundings, misreporting, conversion from kmh to mph and vice versa, every listing of records contains slightly different values. I hoped that by establishing the accuracy of the timekeeping, I could say that the time must have been (say) either 18.001 or 18.002 seconds so a speed corresponding to one of these times is more likely to be correct than one corresponding to 18.001377 seconds and set the record straight.
I'll have to see if I can think of a way to tackle 2-way runs where I don't know the speed in each direction.
