Author Topic: Milwaukee Midget  (Read 2258652 times)
Re: Milwaukee Midget
« Reply #6375 on: August 23, 2017, 06:28:23 AM »
Mark, my guess is that Chris is sure you are the "Anne Sullivan" of motors...  :cheers:
Yeah, that's basically what I do: Teach those blinded by science . . . . . . . . .   :|
Ya know, thinking back on it now, even though I've had some notable successes, I can't say I've really educated more than a handful of racers over 40+ years . . . . . . . . .   :-(
Racers just do not want to listen . . . . .  they want to argue.   I tell them to go argue with my laptop . . . . . . .  :-D
Well Bob, thanks for the compliment.    Unless . . . . .  It just makes me: "One of the girls".   :-D
Notblindedbythelightboy
« Reply #6376 on: August 23, 2017, 06:32:34 AM »
In many ways, you are correct - except the first word I uttered was "BEER!"
Not the first word for me,  :?    probably the second   :cheers:
Thanks for the thought Dan Warner.   "No good story starts with a salad."   How true.  Wish I would have thought of it.
 :cheers: :cheers: :cheers:
Notworthyboy
Offline Speed Limit 1000
« Reply #6377 on: August 23, 2017, 06:56:02 AM »
WOW page 426, such a good number :cheers: could you put a hemi in it :roll:
« Reply #6378 on: August 23, 2017, 07:51:01 AM »
Chrysler, presumably . . . . . .  but probably better to use one of the Chrysler "derivatives"   Way more reliable than an original Hemi block, cheaper too.
As opposed to "rat" based or Ford type hemis . . . . .
Howtofititinboy
  • After further investigation, I/GT record holder
« Reply #6379 on: August 23, 2017, 08:37:48 AM »
Howtofititinboy
Apropos, after last night.
My initial mock up indicates I'll likely need to move the K and transmission further back in the chassis about 4".
The plumbing and electrical on the K is going to be significantly different than the A-series.
Udo Horn said it best - "Every bolt's got to be turned by somebody".
So last night, I popped open the engine compartment and started some dismantling,
Having done this once before on the Midget, and more recently, wiring and plumbing the Frankensprite, I have a better idea as to how to plan ahead on this aspect of the project.
It's often tedious, and while my results have always been essentially functional, I really want to tidy it up this time - proper labels - consistent color coding throughout.
The goal is this - In the event that something goes wrong on the salt, I want to be able to pop the hood and trace a wire with no ambiguity from termination to termination.  I want to be able to hold a multimeter by the fan relay under the dash and say to someone helping me - "okay, connect the fan", and be able to get predictable and repeatable results.
Wherever practicable, every terminal will be soldered and shrinkwrapped.
Not sure yet as to what to do for a radiator.
It was really good just digging in again.  I've missed the fun-work aspect. :cheers:
« Reply #6380 on: August 23, 2017, 09:00:43 AM »
Chris, that is the easiest part.... 5.E.3 paragraph 3.... but you don't have to use it, you might consider a 5 gal. water tank... or using the original fuel tank as a water tank.... you are already outside the box, don't claw your way back in  :-o
« Reply #6381 on: August 23, 2017, 09:16:12 AM »
THAT idea has a lot of merit.  The fuel tank holds 8 gallons, and seeing as I'm going EFI this time around, I should probably be looking at a fuel cell with an integral fuel pump.  Rules don't permit me to remove the fuel tank, but there's no reason I can't fill it with water.
Not that I'm busting 'em loose, but an extra 65 pounds over the rear wheels likely wouldn't hurt, either.
« Reply #6382 on: August 23, 2017, 11:54:10 AM »
Why deviate from the PROVEN Aussie standards??
Yellow
Yellow
Yellow
Just sayin'
 :cheers:  :dhorse:   :cheers:
Stirthepotboy
« Reply #6383 on: August 23, 2017, 11:59:15 AM »
midget,
You might consider sealing the inside of the gas tank prior to adding water.
It is ancient & oxidizing British iron after all . . . . . .   :roll:
All the rest of the reasons are sound though.
Rustyboy
« Reply #6384 on: August 23, 2017, 12:05:46 PM »
Actually, the tank was purchased new in 2010, and has been empty most of the time.  It's very clean and rust-free.
Nevertheless, there is a coating product I'm familiar with that is commonly used on motorcycle tanks.  The question is, will it hold up to 212 degree water?  :roll:
« Reply #6385 on: August 23, 2017, 11:35:48 PM »
Just went through this thread -
http://www.landracing.com/forum/index.php?PHPSESSID=8ad29bd94fe62ce38aee0e89fa1f1059&topic=5314.0
It's late and I'm tired, so when I'm fresh, I'll actually do Harold and IO's math assignments, but given the anecdotal comments as to what is being utilized, I'm thinking an 8 gallon tank for a 130 hp engine going three miles should be an adequate size for cooling.
The question then becomes, do I run it pressurized?
« Reply #6386 on: August 24, 2017, 02:08:15 PM »
We don't -- we run 16 gallons for 5 miles with about 600 H.P. and have never seen 200ยบ.
Past Member of the San Berdoo Roadsters -- "California's Most-Exclusive Roadster Club" -- Fifty-Seven Years of Leadership  Is Enough
« Reply #6387 on: August 24, 2017, 10:10:33 PM »
Well - that was fun.
Using Harold's formula, a 4.95 gallon tank will suffice.  By the time you add the coolant in the lines and block, I'm likely at about 10 gallons of water.
Of course, I could have just listened to the guy who has run a 1 liter lakester . . .
. . . you might consider a 5 gal. water tank...
It's really gratifying when mathematical results and experience confirm each other.  It tends to stop one from barking up the wrong tree.
Stainless - how's John doing?
« Reply #6388 on: August 24, 2017, 10:45:09 PM »
Fordboy -
I've got the "Availability/Price/Shipping" question e-mailed to REC for the valves.  I also asked about collets and compatibility with the Piper spring caps.  Hoping they respond faster than some other suppliers . . .  :|
I may just have them drop-shipped to T&T, if it's okay with Tom and Lenny.
« Reply #6389 on: August 24, 2017, 11:08:49 PM »
Quote from: Milwaukee Midget link=topic=4087.msg306890#msg306890 date=150363
[/quote
I am doing good. Nothing broken except the car. Just resting for a few days.
Johnboy
