Author Topic: Milwaukee Midget  (Read 3269948 times)
Re: Milwaukee Midget
« Reply #5640 on: February 28, 2016, 04:08:03 PM »
You'd better learn the chords:
Oh! Carol
 I am but a fool
 Darling, I love you
 Though you treat me cruel
Neil Sedaka pining for Carol King.   She was dating Gerry Goffin @ that point, and later married Gerry.
Neil didn't get any respect!
Formerlybassboy
« Reply #5641 on: February 28, 2016, 04:13:08 PM »
Why should the midget treat the K any better than he treated the "Grenade"?
« Reply #5642 on: February 28, 2016, 08:00:00 PM »
Would that be the infamous DCB?
We have a winner.
Midget... I kinda like K1K.... maybe the engine will have a little kick....
We have TWO WINNERS!
K1K it is - I'll get to work on the graphics.
Oh! Carol
 I am but a fool
 Darling, I love you
Hadn't thought of that one - Sedaka is one of the greats, but when I hear the song "Carol", I think Chuck Berry or Keith Richards -
https://www.youtube.com/watch?v=Wfj1O_fApvA
Keith openly admits he stole every lick Chuck ever wrote.
« Reply #5643 on: February 29, 2016, 10:24:02 AM »
midget,
What is the chance of a trial fit up of the head/barrel(s)/block/ladders/studs/etc, sometime soon?
I'm looking to check the clearance of the o/size valves to the edge of the bore size of the barrels.
« Reply #5644 on: February 29, 2016, 06:20:45 PM »
I'll do a partial assembly tonight and have it ready to check when the head arrives on Wednesday.
I'd like to avoid putting all of the liners in place, if I can help it.  Seeing as you've set up one chamber for the proposed valves, which cylinder(s) will we be checking?
I'll charge up the borescope.
« Reply #5645 on: February 29, 2016, 06:32:10 PM »
For a "boronoscopy?  :-o  :cheers: Wayno
« Reply #5646 on: February 29, 2016, 07:33:32 PM »
 . . . . ahhh . . . . . . sure . . . .
« Reply #5647 on: March 01, 2016, 05:14:43 AM »
Just cylinder #1
« Reply #5648 on: March 01, 2016, 07:37:49 AM »
midget,
midget,
Here are a few photos I shot at T & T last week.    The bore of the flow bench slider is 76mm, the biggest I thought would ever be utilized.    Proposed bore of current design 75.5mm, so roughly .010" less radially.   At 75mm, the reduction would be ~ .020" radially.
Uncut stock seats
Oversize valves fitted
Close-up of fitted oversize valves
It is probably OK because of the valve angle, but, it is close.   Given this bore size and valve centerline spacing, K1K is maxed out.
A shot of the head and valve opening rig, on the flow bench.
One more view from a different angle.
There is a bit of variation in the chamber to bore clearance from cylinder to cylinder.   It might be how I made the slider adaptor, or it might be some variation in the head casting(s).
That's the reason to check it.   If the bore appears to be centered more precisely on the block/barrel, I going to cross it off the list of things to be concerned about.
« Reply #5649 on: March 01, 2016, 10:59:01 AM »
I'll be by tomorrow AM with the block, etc.
Won't be working on it tonight, though.  Kate's birthday takes precedent.
« Reply #5650 on: March 01, 2016, 11:41:41 AM »
Well, of course!!
Even Dr.Phil advocates keepin' momma happy!
Our best wishes to Kate on what we understand is an eventful day . . . . .
 :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
Mr. & Mrs. Fordboy
« Reply #5651 on: March 01, 2016, 11:42:47 AM »
Happy Birthday Kate. :cheers:
« Reply #5652 on: March 01, 2016, 11:47:26 AM »
midget,
Dimensions of stock BMC 1275 wrist pin:
Inside Ø     ~.510"
Outside Ø     .8125"
Length       ~2.50"
And they are hard enough.    Seems like the perfect spacer for the new torque plate.   Might have to grind the ends flat and square . . . . . . . .
Alternatematerialsourceboy
Ahhh, on second thought make that:
Repurposingboy
« Last Edit: March 01, 2016, 11:50:22 AM by fordboy628 »
« Reply #5653 on: March 02, 2016, 06:50:13 PM »
MM ventured out below the "cheddar curtain" today, taking a rare day off with the intention of checking out the clearance between the valve edges of the over size valves and the edge of the 75mm bore cylinder.
Things checked out OK, there is a bit of "casting misalignment", what you would expect from a cast part.  Checking was done on cylinders #1 and #4.   It is a tight squeeze, 5 pounds of parts in 3 pounds of space, similar to late model 4 valve bike engines.    Valve area is not as great as on a bike engine, but given the valve spacing and bore diameter limitations, the valve sizes being evaluated are "maxed out" for the combination.      MM shot some inspection cam video, perhaps he will post it up to the diary.
The larger diameter valves give the benefit of allowing some valve throat and valve pocket machining and matching, correcting some fairly serious misalignment in that area of the cylinder head.    The flow increases have been quite good for the amount of effort expended in these areas.
Some time was spent in the "Dungeon Laboratory" crunching some of the flow test data, and as soon as the test notes have been edited, I'll be posting a "Data Dump".    I'm working on a more comprehensive simulation in EA Pro, once that is done, an additional "dump" is planned.
There was a side trip to the shop of the Mini Maven to return some borrowed bits from the "Grenade".    Luncheon was at the local pub.
Offline jacksoni
« Reply #5654 on: March 02, 2016, 07:04:44 PM »
"Luncheon was at the local pub."
Surprise, surprise!! :-D :cheers:
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
