Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
Open rear or ????
« previous
next »
Pages: [
1
Go Down
Author
Topic: Open rear or ???? (Read 2382 times)
Blanding, Ut..a small dot in the middle of nowhere
Open rear or ????
on:
December 21, 2004, 01:05:00 PM »
I'm building a J/GL with about about a 51 inch hub to hub width front and rear and the car will have about a 13 foot wheel base.
If you had your choice of an open rear or spooled rear, which would you run and why.
Thanks for your opion,
Lakester Construction
My Bonneville Pages
1FATGMC
RichFox
Re: Open rear or ????
Reply #1 on:
December 21, 2004, 01:30:00 PM »
I have run both and would run an open rear untill I experianced spinning one tire at speed. Not likely with a "G/GL".
jimmy six
Reply #2 on:
December 21, 2004, 06:59:00 PM »
If you use a locked rear and spin take it out. If you use an open rear and spin put one in....Words from an old salt racer I overheard once..But I think perfectly round and same size tires at the same pressuse would make a lot of sense either way. JD
Gary Perkinson
Reply #3 on:
December 22, 2004, 12:19:00 PM »
I was thinking about putting a mini-spool in my 8-inch Ford rear (for my C/CGALT Pinto), but I've decided that since launching is not an issue and I'm going to be running an automatic, the open diff will probably work just as well. Then again, I don't have salt experience, so I could very well be talking out the ol' butt....
Gary
LTA G/BGALT Record (1 mile) 143.313
LTA G/BGALT Record (1.5 mile) 148.321
LTA F/PRO Record (1 mile) 114.668
Reply #4 on:
December 23, 2004, 02:31:00 PM »
Thanks Rich, JD and Gary for your thoughts. I guess I'll keep it an open rear with provisions to lock it if that seems better.
c ya and have a good Holidays, Sum
My Bonneville Pages
1FATGMC
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
Open rear or ????
