Author Topic: Fire System  (Read 2097 times)
Justin
Fire System
« on: October 28, 2004, 06:48:00 PM »
Thank you for all of the help/advice.  I see that the fire system needs a current inspection/filing certification each year.  Typically what is the procedure to get this done?  As you can tell I have a lot to learn.
Offline jimmy six
Re: Fire System
« Reply #1 on: October 29, 2004, 11:38:00 AM »
Depending on the system you choose. Most fire extinguisher service companies can weigh and test your system...However some are manufacturer specific..If you are looking to buy, find out what is the companys requirements for inspections. If you need to ship it to get inspected a pressurized bottle can be a problem....Good Luck...I would also advise you to keep the reciepts with your log book....
