Well, I was wrong- this block has oil screens, too.
I wondered where all the oil was going as I was priming the oil pump so I removed the intake manifold to have a look. Evidently my oil pump drive adapter has a very poor fit into the distributor hole so the oil was being pumped up into the valley and when I turned off the drill, it drained back into the pan. The oil was accumulating in the valley because the oil was being pumped up faster than it could drain back. Now I'm satisfied that the oil system is OK so I bolted the intake back on.
I had forgotten about the screens but I'm glad they are there; if a needle bearing in a roller lifter disintegrates, the screens will keep most of the debris from draining back into the pan and getting sucked into the oil pump.
Regards, Neil Tucson, AZ
