I removed the front suspension of my black Mirage today so that I can finish welding some places on the chassis. As long as they were being removed anyway, I thought I’d weigh them to see how heavy each side suspension is.
The weight is 45 lbs—this includes the Mustang upright, aluminum hub & wheel studs + lug nuts, big brake rotor, aluminum ‘88 Corvette caliper & bracket, ball joints, tube a-arms, all the rod end bearings, and mounting bolts. Also included are Aldan aluminum shocks & coil springs.
This is a little heavier than I had guessed but still not bad. Together with the wheel & tire, the total unsprung weight on each front end is 45lbs + 32 lbs = 77 lbs. Actually it is a little less than this because the inboard ends of the a-arms are supported by the chassis.
Just out of curiosity, I put a few more of the disassembled black Mirage components on a scale to see how much they weighed. Here is the data:
Front subframe with riveted panels installed: 21 lbs
Aluminum Howe radiator: 12 lbs
Wilwood rack & pinion complete end-to-end: 10 lbs
Front anti-roll bar, mounts, & drop links: 4 lbs
Bassett front wheel & Goodyear racing slick: 32 lbs
Bassett rear wheel & Goodyear racing slick: 49 lbs
Although I haven’t weighed them, published data indicates:
Porsche G50 transaxle: 142 lbs
Donovan all-aluminum SBC: 390 lbs
I hope to weigh the Mirage body sections and the chassis + roll cage later.
Regards, Neil Tucson, AZ
