A little more progress-- I'm still waiting for a 2 9/16" hole saw that I ordered so I haven't installed my oil pressure, water & oil temperature gauges in the instrument panel yet but I did get a few more indicators in. In the meantime I made a little aluminum panel for all my Panel- mounted switches and circuit breakers. The circuit breakers that I'm using are made by Airpax and look like toggle switches. In fact, they are made to be used as switches with a built- in circuit breaker action. More neat aerospace surplus stuff.
The round buttor is a pushbutton switch for the starter, next is the main power switch with a switchguard so I can simply bat at it with my gloved hand to shut off all electrical power, the other toggle switch is for the ignition.
I have two 80 amp auto- reset breakers that I'll mount elsewhere. One big breaker will be in series with each relay- switched 12V power buss.
Regards, Neil Tucson, AZ
