Author Topic: Mid- Engine Modified Sports  (Read 786626 times)
« Reply #1770 on: January 31, 2020, 07:01:54 PM »
I made another small improvement to my shift linkage. The end of the shift rod has a 1/2" 6061-T6 right angle piece that functions to rotate the transaxle shaft and push it in & out. I used an aircraft counterbore to make a 3/4" hole for the 0.750" shift rod. It turned out the hole was bored about 0.020" oversize so I used some 1/4-28 set screws to secure it to the shaft. This worked OK but I thought that I could reduce the chance of rocking back and forth when shifting by adding a second thickness to it. By bolting the two pieces together with a 5/16-24 Ti bolt, the two pieces are held rigidly together. So far so good...
« Reply #1771 on: January 31, 2020, 10:52:26 PM »
Neil, you could put some divots in your rod for the 1/4 set screws to prevent any slipping/rocking issues.
« Reply #1772 on: February 01, 2020, 10:53:10 AM »
Yes, I plan to do that when everything is adjusted to its final position. Here is what I'll do (but without the hole). Set screws don't bite into the Rockwell C60 surface of that shaft.
« Reply #1773 on: May 03, 2020, 09:12:12 PM »
I just posted a video on YouTube.
https://www.youtube.com/watch?v=XUAYETAsdL0&feature=youtu.be
It's my first time at putting one together.
Offline salt27
« Reply #1774 on: May 03, 2020, 10:40:43 PM »
Nicely done Neil.    :cheers:
« Reply #1775 on: May 03, 2020, 10:58:25 PM »
Thank you, Don. This was my first effort at creating & editing a video.
« Reply #1776 on: May 03, 2020, 11:05:12 PM »
Neil,
That was great. You video looked like a professional did it. Thanks for sharing.
 :cheers: :cheers: :clap :clap
PS. Put that puppy on a chassis dyno and get a basic tuneup.
« Reply #1777 on: May 03, 2020, 11:08:48 PM »
Thanks, Tom. I plan to do that when things get back to normal.
« Reply #1778 on: May 03, 2020, 11:24:19 PM »
That movie is well done.
« Reply #1779 on: May 03, 2020, 11:26:42 PM »
Thanks, WW. I'm new to video stuff.
Offline floydjer
« Reply #1780 on: May 04, 2020, 09:37:46 AM »
Nice video Neil.
« Reply #1781 on: May 04, 2020, 09:45:01 AM »
Neil:
Good job, I enjoyed it. You might hold a record for the most work per mile per hour!
The car will be fast, just need an event and good salt to let that beast eat!
« Reply #1782 on: May 04, 2020, 10:31:06 AM »
"You might hold a record for the most work per mile per hour! "
That is a dubious honor for sure!  :cry:
« Reply #1783 on: May 04, 2020, 01:25:07 PM »
You are in good company. There are a lot of us.
You car looks great on the salt. Neil I am certain there is a record in your future. Enjoy your workmanship.
Offline DallasV
« Reply #1784 on: May 04, 2020, 01:40:10 PM »
This could be an educational video on what to expect the first time you bring you car to car to the salt. It looks so easy when you see those racers that have been doing it for years and years but we have all experienced what this video shows.
