I’ll set up a depth mic and check the height of each piston at TDC, that should me tell if any rods are bent. The dust/corrosion may be too deep for the rings to seal even if the cylinder is touched- up with a hone. Since I did not know that water had leaked into the intake, it set with water in the cylinders for a couple of weeks. I suspect that I’ll need to hone or bore it to the next oversize. I do have a bore mic so I’ll check it. I might be able to get by if it was a mild street engine but not a race engine. The KEP pressure plate uses a bolt-on ring gear so I’ll just order a new one and install it. The starter pinion gear looked OK by eye but I’ll check it more carefully under a magnifying glass. Tomorrow I’ll pull off a few bearing caps and wipe as much oil as I can off of everything to get a better look.
It is beginning to look like the reason the engine went down on power and then quit may have been due to two things- the carburetor power valve was too high so that even at modest throttle, it was opening and dumping way too much fuel into the engine. And, listening to the video of my run, it is clear that the RPM drop from the shift from first gear to second was way too much. I now think I accidentally shifted from first to fourth, so the large throttle opening at low RPM just flooded it with too much fuel. The driver of a chase truck commented that black smoke was coming from the exhaust. This supports the too much fuel rather that my fuel starvation theory after I found that my fuel suction filter was 10u instead of 100u.
My shift pattern is reversed (1st is to the left and back, second is to the left and forward, etc) so I’ll change the shift lever pivot point to make it a standard pattern. It’s hard to unlearn a shift pattern. Smile
Regards, Neil Tucson, AZ
