Author Topic: Mid- Engine Modified Sports  (Read 787315 times)
« Reply #1410 on: July 19, 2017, 07:05:57 PM »
Stan;
I would if I had any more decal material. I don't even have the ol' tried and true drag racing "white shoe polish."  :-)
« Reply #1411 on: July 19, 2017, 07:25:24 PM »
You can buy colored duct tape at craft stores.  Many other uses.
« Reply #1412 on: July 19, 2017, 07:26:34 PM »
Good idea, Stan-- thanks!
« Reply #1413 on: July 19, 2017, 11:17:45 PM »
Stan - please, no, perish the thought.
Neil, if it is truly a concern, there are dozens of other options that leave less residue and clean-up.
In the AV business, we tend to have to deal with a lot of people who fancy themselves as stage hands.
« Reply #1414 on: July 20, 2017, 02:08:09 AM »
 :-D  :-D  :-D  Thanks, Chris!
Offline floydjer
« Reply #1415 on: July 20, 2017, 09:25:19 AM »
Make a slash and put it there -- It would be more appropriate.
yeah, That`ll help...............
« Reply #1416 on: July 20, 2017, 09:47:53 PM »
Better? ( I need to re- position it, though).
« Reply #1417 on: July 20, 2017, 09:53:43 PM »
Much better  :-)
« Reply #1418 on: July 21, 2017, 01:00:55 AM »
In all honesty, if this is the biggest issue you've got going into Speedweek, you're not going to have any problems.  :-D
We will see you in a few weeks.
A close-up of this car - along with a certain small-bore lakester we've been watching - will be the highlights.
« Reply #1419 on: July 22, 2017, 10:05:42 PM »
I am almost finished with my swing-away lateral head support. In the photo, the support bar looks crooked but when it is bolted down to a flat surface, it is straight up. The bar is held in place by a 1/4" quick-release ball lock pin and to release it to swing away, a lanyard is pulled to drop out the pin. If I can find a good torsion spring, I'll add one (maybe a rat trap spring might work).
Regards, Neil  Tucson. AZ
« Reply #1420 on: July 22, 2017, 11:25:20 PM »
Just make sure it's locked into place before you slam the door - they can be hard on Lexan . . .
don't ask . . .  :|
« Reply #1421 on: July 23, 2017, 11:47:30 AM »
I can believe that, Chris!
« Reply #1422 on: July 25, 2017, 09:31:59 PM »
My intake manifold has been modified for EFI but I'm currently running a Holley 850 DP so up to now I have been plugging the EFI bungs with injectors. The ID of the bungs measured only a few thousandths over 5/8", so I placed small 5/8" oil galley plugs into the bungs (they were a slip fit into the holes) and sealed them with silicone RTV.
The new push-pull cable throttle linkage is now installed and it is far smoother than the Bowden cable. Now off to work on other things.
Offline handyguy
  • BANTAM FOURPLAY
« Reply #1423 on: July 25, 2017, 11:07:40 PM »
If it wasn't for the details , the car would have been done last year !!   STEVE
Offline Buickguy3
« Reply #1424 on: July 26, 2017, 08:02:50 AM »
Neil, Those plugs will make great "blowoff valves" in case you ever float a valve or something like that.
  Doug, See you in a few.  :cheers: :cheers: :cheers:
                   [America]
