Author Topic: Mid- Engine Modified Sports  (Read 787159 times)
« Reply #1305 on: May 22, 2017, 05:06:28 PM »
I mounted the rear body on its new pivot pins and found that my original stays (which support the rear body in the open position) were too long now. After adding a rear spoiler, the body opened so far that the rear of the spoiler end plates hit the ground. Arrgghh. I shortened the stays so it is now slightly above ground level.
I'm waiting for a call back from Bob Stroud so that I can place an order for a chute and spring launcher. My number decals should be here on Wednesday.
« Reply #1306 on: May 22, 2017, 05:17:18 PM »
Neil:
It looks like things are really coming together quickly now.
Can't wait to see it on the salt!
« Reply #1307 on: May 22, 2017, 07:10:44 PM »
Thanks, Steve. I wish it were coming together even quicker but it is what it is.
« Reply #1308 on: May 23, 2017, 09:30:41 PM »
I'm cutting clearance holes in the seat tub for a 7-point safety harness and fitting the tub into the chassis. It wouldn't go far enough to the rear so I placed a wad of modeling clay on the fire bottle & T-bolt clamp fasteners to see where it was hitting. Sure enough, it looks like I'll have to cut about 3/4" off the threaded clamp fasteners; a small cut-off wheel is probably the best approach.
Offline jdincau
« Reply #1309 on: May 23, 2017, 11:08:00 PM »
Cant really tell, they look like the all metal oval hole type but be careful if the self locking nuts have elastic material it could melt.
Offline Ray-Zee
« Reply #1310 on: May 24, 2017, 01:13:04 AM »
great progress
« Reply #1311 on: May 24, 2017, 01:46:36 AM »
Looking good Neil.
Making progress. :-D :cheers: :cheers: :cheers:
Offline salt27
« Reply #1312 on: May 24, 2017, 08:25:26 AM »
Neil, could you turn the mounts so the threads are facing the other way?
« Reply #1313 on: May 24, 2017, 11:21:24 AM »
Jim;
I plan to temporarily replace the elastic stop nuts with ordinary 1/4-28 nuts when I cut the studs so there will be no problem from the heat. After cutting, removing the nuts over the cut ends will swage the threads back into shape. Then I'll replace the locknuts.
Don;
Moving the mounting straps would involve removing & replacing 20 rivets plus getting a wrench on the nuts facing backwards would be a bit more difficult. Good idea, though.
« Reply #1314 on: May 24, 2017, 11:56:37 AM »
Hey Neil, I guess you do know what you're doing. 8-)
These cars keep the brain working overtime.
I find I have to work 5 steps ahead all the time.
Tough deal but like they say if it was easy......... :cheers:
« Reply #1315 on: May 24, 2017, 10:35:05 PM »
Well, Mike, sometimes I wonder if I do....  :-)
Yay!!!
The Brown Santa brought my number decals today!  “291” is my car number, “BGMS” is my class- B Gas Modified Sports, and my name for the driver’s side door. The paper backing will be removed during application so the letters should contrast nicely with the black body.
Offline GH
« Reply #1316 on: May 25, 2017, 09:00:47 AM »
Neil, I had "What Me Worry" on a 1953 Olds back in 1960.
« Reply #1317 on: May 25, 2017, 09:08:54 AM »
Neil, maybe should have bought a dash or slash so it doesn't look like blown gas modified sports  :|
« Reply #1318 on: May 25, 2017, 10:09:09 AM »
No problem, Stainless -- Neil probly already owns a razor blade and some white shoe polish -- easy to fix up that set o' stickers and make 'em look more home spun, too :-D
« Reply #1319 on: May 25, 2017, 11:00:36 AM »
Stainless is absolutely right! I should have put a slash in there: "B/GMS" Oh well, Jon's idea of a razor blade will save the day.
