Author Topic: Mid- Engine Modified Sports  (Read 787624 times)
Offline floydjer
« Reply #1155 on: November 29, 2016, 09:10:49 AM »
top notch work Neil. pun intended.
« Reply #1156 on: December 04, 2016, 05:34:31 PM »
I just ran into an interesting problem- while I was bolting on my newly made rear body brackets, I noticed that the left exhaust header was a little loose. I thought that I had torqued the bolts but maybe I hadn't, so I tried to tighten the bolts that fasten the header flange to the head. No dice, they were tight! I found that the bolts were bottomed in the head. These are new ARP 3/8" UNC bolts with a 1.00" grip length and an ARP 0.050" thick washer.
Odd- has anyone run into this before? The heads are Dart aluminum heads. I added two 0.063" stainless washers as spacers and now it seats properly. Strange! Both L & R header bolts were bottomed. PITA  :x
« Reply #1157 on: December 04, 2016, 06:25:43 PM »
"ARP 0.050" thick washer"
I'd call that a thin washer.  Were the bolts specified for your heads with the flange you're using?
« Reply #1158 on: December 05, 2016, 12:54:37 AM »
Neil, most of the time on bikes threaded studs are put in the holes near the manifolds.  Nuts are tightened down onto the studs to hold down the manifolds.  This prevents the problem you are having.
Offline jacksoni
« Reply #1159 on: December 05, 2016, 07:38:45 AM »
Sounds like the header bolt holes are barely .500" deep. How deep are the rest of them? Seems like machining error to me. Might run it by Dart and see what they say.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #1160 on: December 05, 2016, 11:14:45 AM »
I'm with Jack on that... my preference is at least twice the bolt diameter when going into aluminum.
What torque is called out for those bolts?
« Reply #1161 on: December 05, 2016, 11:30:40 AM »
Stan- Yes these are the recommended bolts for this header flange and Fel-Pro gasket.
WW- There is not much room between the bolt holes in the flanges and the tubes on a SBC header. These bolts are a "reduced head" so that you can get a 3/8" hex wrench on them. I think a nut would not fit leaving wrench or socket clearance.
Jack- I think the threaded depth is about 0.925".
Bob- There is plenty of engagement, over 2 x 0.375". Dart calls for 35 ft-lbs torque on the header bolts.
« Reply #1162 on: December 05, 2016, 12:25:07 PM »
Neil, how thick are your header plates. I've always used 3/8" plate as a minimum. I've never seen headers with 1/4" plate flanges that seal properly for very long.
Are the holes tapped to the bottom of the hole. You may want to invest in a bottoming tap of the correct size and thread and go through each hole. It's worth getting a proper aluminum tapping fluid such as A-9 or Alumicut when you do the tapping.
« Last Edit: December 05, 2016, 12:29:23 PM by Peter Jack »
« Reply #1163 on: December 05, 2016, 09:10:52 PM »
Pete;
These are Schoenfeld SBC headers. I think they have 3/16" thick flanges.
« Reply #1164 on: December 05, 2016, 10:41:18 PM »
That sounds like something built for the ultimate in weight saving. Schoenfeld build a lot of oval track headers and those guys sometimes do some ridiculous things to save weight. Keep a close eye on them because they'll likely have a tendency to warp.
Bo's idea of using studs is a good one and totally legitimate. You can get reduced head nuts similar to the bolts you're using now. Using them will reduce the wear on the threads in the heads. Just be sure to adjust the torque values if the studs are fine thread.
« Reply #1165 on: December 06, 2016, 03:47:37 AM »
Neil, I think Bo is on the money.
Studs make fitting so much easier especially on headers.
I know you'll resolve the issue no problem. :cheers: :cheers: :cheers:
« Reply #1166 on: December 06, 2016, 10:47:42 AM »
Pete;
You are right, these are circle track headers. That must explain why the screws bottomed out in the holes- thinner flanges.
I wasn't aware of reduced size hex nuts; I'll check into those.
This forum is so helpful, I learn something here all the time- thanks!
Offline jacksoni
« Reply #1167 on: December 06, 2016, 10:55:35 AM »
Pete;
Not so much hex nuts perhaps. 12 pt. I use them a lot on my engine. ARP has them.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline salt27
« Reply #1168 on: December 06, 2016, 11:18:38 AM »
The downside to 12 point is that you can't use an open end wrench on them.  :-P
« Last Edit: December 06, 2016, 11:26:14 AM by salt27 »
Offline jdincau
« Reply #1169 on: December 06, 2016, 11:34:42 AM »
These work well but you need to locktite the studs in place as the lock nut is pretty aggressive.
http://www.aircraftspruce.com/pages/ha/nut_hex/ms21042.php
