Author Topic: Mid- Engine Modified Sports  (Read 787050 times)
« Reply #1125 on: September 07, 2016, 08:30:56 AM »
Neil, the only thing you haven't shown us is the landing gear!!!.
That's built like a plane. AWESOME!!! :cheers: :cheers: :cheers:
I love your work and it's great to see pics again.
You inspire me.
« Reply #1126 on: September 07, 2016, 12:57:48 PM »
WW;
Wheelrdealer's solution is an excellent one. The cause of the breakage is flexing the wire at points where the solder has wicked up into the strands, making those points a transition in the wire from flexible to rigid. This concentrates the stress and the wire breaks from fatigue. A butt crimp eliminates the solder wicking but it still needs some mechanical support such as the meltable inner wall shrink tubing he suggested.
« Reply #1127 on: September 07, 2016, 10:03:03 PM »
I needed a new ignition wire from my coil to the distributor post so I ordered a kit from Taylor/Vertex. They make a very nice ignition wire called "409" which is a large-diameter (10mm) silicone insulated wire with a core resistance of 400 ohms per foot. My Crane ignition box specifies this resistance for best operation. I'll post a picture of the distributor end, before the boot is installed and before it is bent 90 degrees. Taylor makes good stuff.
« Reply #1128 on: September 13, 2016, 06:28:31 PM »
More little tasks. I wanted to give some support to the fiberglass nose of my Mirage so that aerodynamic down force wouldn't cause it to deform too much. I had a 1 3/4" gap between the bottom of the fiberglass and the top of the forward bulkhead that I needed to seal anyway so I found an aluminum extrusion that was the perfect size, a 1 3/4" tall "C" section that both supported the nose and sealed the cockpit. Lucky find.
To fasten the extrusion to the fiberglass, I pressed in five floating captive nuts. There will be 4-40 screws thru the 'glass and into the captive nuts. This way I can remove the extrusion when I remove the front body work.
« Reply #1129 on: September 13, 2016, 08:37:43 PM »
The access panel in the nose is simply flat fiberglass with a small remainder of 'glass that was cut off so it wasn't as stiff as I'd like; down force might distort or bow the panel so I added two aluminum angles on the underside. They are 1" x 1" x 0.060" 7075-T651, zinc chromate primed and fastened on with a row of 1/8" Avex rivets. This added a lot of rigidity to this panel.
« Reply #1130 on: September 14, 2016, 04:00:38 AM »
Looks good Neil.
I always like to bond and rivet when doing jobs like that.
That way the glass doesn't have chance of tearing the holes or opening them.
Offline Finallygotit
« Reply #1131 on: September 14, 2016, 10:23:47 AM »
Looks good Neil.
Note to self, remember this.
Dan
Tucson, AZ
« Reply #1132 on: September 14, 2016, 11:41:12 AM »
Good advice- thanks, Mike.
« Reply #1133 on: September 15, 2016, 12:20:09 AM »
Thanks for the advice about the wiring problem.  I had been using the single wall shrink tubing and it was not enough.  The double wall works a lot better.  Also noted are how you secure the wires to the frame so they do not wiggle.
« Reply #1134 on: September 24, 2016, 09:27:21 PM »
I thought I'd take my car to the "Tucson Classic" car show next month after Joline and I return from a trip to Normandy. Since I'm tired of explaining what it is-- people always ask-- and I'm tired of saying "Its just a car that I'm building", I've decided to name it: Werewolf.
It's black, sinister looking and I've never seen another car with that name.
Off to France on Monday morning. After a bit of polishing, it is ready to put on the trailer when we get home.
« Reply #1135 on: September 24, 2016, 11:59:26 PM »
Neil, that looks great.  Was it hard to register a car that you made yourself?
« Reply #1136 on: September 25, 2016, 12:06:03 AM »
Looks great Neil. Well done.  :cheers: :cheers: :cheers:
« Reply #1137 on: September 25, 2016, 01:58:24 AM »
Beautiful Neil. Have a good trip. :cheers: :cheers: :cheers:
« Reply #1138 on: September 25, 2016, 10:03:58 AM »
WW... I think its a race car.... no lights... no horn... looks like it would be hard to do hand signals, especially when he is strapped in  :roll:
« Reply #1139 on: September 25, 2016, 10:33:48 AM »
"Better stay away from him
He'll rip your lungs out, Jim
I'd like to meet his tailor"
Warren Zevon
