Folks, I am not reviewing, criticizing, or suggesting change to any existing car or fabrication. As far as I am concerned you are the test pilot and we can all learn from your experience. My comments are offered only for additional thought by others that may be studying the idea but have not posted to this thread. Secondly,I am not an engineer or a physicist so YMMV.
Some thought should be given to the relative wind. Relative wind is defined as any wind direction other than straight down the track. An example would be a left front crosswind coming from 45 degrees. Other than slowing you down, the effect on the car is far more complicated. Most people figure the car will start to fly when you are going perfectly backwards straight down-track. While true, it is a least likely scenario because lift can be generated long before you go around to 180 degrees.
If you are going 200 mph into a left front crosswind you do not have a 200 MPH wind straight down the car but a lower velocity component of that wind flowing over the car. (Pilots whip out your trusty E6-B here) However, many times a vehicle enters a spin and deviates 15-30 degrees from the course which can be either into or away from the wind. Depending on direction, this course deviation further amplifies the relative wind effect. So even though aero is different for every car, and ambient conditions vary widely, the possibility remains that under the right conditions, a vehicle could lift off with much less than 180 degrees of rotation.
May all your winds be at your six!
