Author Topic: Rolling Resistance  (Read 47393 times)
Offline thecarfarmer
Re: Rolling Resistance
« Reply #30 on: August 18, 2012, 12:40:00 PM »
The formula I have is N = W x V x T / 270 where N is the power required, W is the weight in kilograms, V is the speed in kilometers per hour, and T is the rolling resistance of the tire.
 (snip)
Units for "N"?  Newtons or KWH, or something?
Thanks!
-Bill
We all enter this world in the same way: naked; screaming; soaked in blood. But if you live your life right, that kind of thing doesn't have to stop there.
-Dana Gould
Offline Jack Gifford
« Reply #31 on: August 19, 2012, 12:40:08 AM »
You'll need Ratliff to answer about the formula he posted. To utillize his formula, you'll also need (besides units for N) units for T.
The units for N must represent power; Newton is the MKS unit of force, not power, and KWH is a unit of energy, not power.
M/T Pontiac hemi guru
PatMc
« Reply #32 on: August 19, 2012, 02:40:58 PM »
One thing I've never got a solid answer out of, is if LSR tires slip.  Slip is not spinning.  It's the stretching of the rubber.  With no loss of traction, a tire can move the vehicle less than it's circumference when torque is applied.   This is normal on non-LSR tires.
Think of a centipede crawling.  Tires do the same thing when torque is applied.
Offline hotrod
    • Black Horse photo
« Reply #33 on: August 19, 2012, 04:11:12 PM »
No rolling resistance is a force, to compute the power needed to over come it you need to know how fast the car is going.
N = newtons the force resisting motion.
There are several other rolling resistance formulas out there in various engineering texts and some books on aerodynamics, mention it as well.
The best way to determine it is to use low speed coast down information where the dominant form of drag is rolling resistance rather than aerodynamic drag.
Larry
« Reply #34 on: August 20, 2012, 01:27:56 AM »
Talk about muddying the water...
Offline Harold Bettes
  • Firebase High Country
« Reply #35 on: August 20, 2012, 04:48:21 PM »
A Newton is equal to .2248089lbs force. Or, 1lbf = 4.448222 Newtons. :roll:
And of course, one needs to consider a sign change for resistance in calculations. :-P
Once you get started in force calculations for a salt rider, lots of things are happening (in motion) at the same time. :-D
It is however much more simple than attempting to keep up with the National Debt Clock. :-o
Regards to All,
HB2 :-)
« Reply #36 on: August 20, 2012, 08:43:56 PM »
The best we can do with this complicated situation is to collect data from our runs and to develop slip coefficients for the combination of driver and vehicle.  There are so many things happening and one of the most significant is the driver/rider.  Some people know how to go fast by minimizing the application of excess power and the resultant slip.  Others do the opposite.
Offline Old Scrambler
  • Going Fast - Slowly
« Reply #37 on: August 24, 2012, 09:03:39 PM »
About 2 years ago I started making plans to build a bike for the salt-flats. I knew it would be a Triumph Cub with about 20 hp and rather light, yet it had to carry my 200 lbs. of body weight.  I did not consider the amount of energy or power I would need to overcome rolling resistence. Rather, I thought about selecting the lightest, roundest, narrowest, firmest, and most reliable tires and wheels available within my almost nothing budget. From a practical point of view, I know that once the wheel is put into motion, a larger diameter is easier to push or pull with my own strength, such as a wheelbarrow or wagon. Practical experience seemes to work. I can almost effortlessly push my bike across the salt with one hand and when I stop I actually have to reverse my effort on the bike if I want it to stop with me. That's my formula......Oh, BTW.....how many minutes does your wheel keep spinning when suspended after you give it a good start ?
Offline tallguy
« Reply #38 on: March 11, 2024, 02:18:23 AM »
I can imagine that an LSR tire could slip (in relation to the wheel that holds it).  But on salt or dirt, which provides less
traction than asphalt or concrete, this is probably not very common, especially since land speed racers typically use a lot
of air pressure in their tires.  This would tend to hold the bead of a tire pretty firmly against the rim, discouraging slippage.
You probably know about dragster tires being secured to their wheels using screws.  I'd lean more toward adhesive
material to do this trick, if I had a tire slippage issue in land speed racing.
Offline 55chevr
« Reply #39 on: March 11, 2024, 06:01:53 AM »
This thread is 12 years old
