you didnt read page 15 of the rule book willie in casse you dont have one
2.A ENGINES any internal combustine engine using either a two stroke or four stroke otto cycle or diesel may run in any category --------------------------------------------reaction propulsions engines are prohibited.
you can run pretty much anything you want at an s c t a event if it will pass tech but if it wont fit into a class you will have to run for time only no record
if you're going to ban reaction propulsion then you also have to ban header configurations like the ones on Goldenrod and Challenger 1.
The SCTA has classes for turbine cars. The rulebook doesn't say they have to be airbreathers nor does it say there has to be a direct mechanical connection between the gas generator and the power turbine. Just as Leopold Schmid proposed placing a paddlewheel in the exhaust stream of a jet engine, a paddlewheel could also be placed in the exhaust stream of a rocket engine.
Aside from that, there are no rules prohibiting the installation of propellers on piston engine or turbine wheel driven cars since propellers are not a form of reaction propulsion.
"Reaction propulsion is generally defined as the propulsion of a craft produced by the forward directed forces of a reaction resulting from the rearward discharge from the craft a high-speed stream of matter, most frequently fluid. Jet propulsion and rocket propulsion are included in the definition of reaction propulsion."
"Noun 1. reaction propulsion - propulsion that results from the ejection at high velocity of a mass of gas to which the vehicle reacts with an equal and opposite momentum
jet propulsion - propulsion by means of the discharge of a jet of fluid toward the rear
propulsion - a propelling force
rocket propulsion - reaction propulsion using stored oxygen for combustion; used where there is insufficient atmospheric oxygen"
"reaction engine - WordNet (r) 2.1 (2005) :
reaction engine
n 1: a jet or rocket engine based on a form of aerodynamic
propulsion in which the vehicle emits a high-speed stream
[syn: reaction-propulsion engine, reaction engine]"
"reaction propulsion
noun
Source: WordNet (r) 2.0"
"Noun: reaction propulsion
Propulsion that results from the ejection at high velocity of a mass of gas to which the vehicle reacts with an equal and opposite momentum
Derived forms: reaction propulsions"
