Author Topic: so how long is the shutdown area/  (Read 6547 times)
Offline Carl Johansson
« on: May 04, 2008, 10:36:32 AM »
so after you go through the traps,  how much shutdown is there at Goliad?  I went to their website,  but couldn't find it anywhere.  In the supercars show shot there,  the guy says it's only 1/2 mile of shutdown,  and that does't seem right!
Carl Johansson
Carl Johansson
 Auberry Ca
Re: so how long is the shutdown area/
« Reply #1 on: May 04, 2008, 12:00:33 PM »
Carl Johansson
I think Stainless told me maybe even less than that.  Stainless??
Offline 1 fast evo 2
« Reply #2 on: May 05, 2008, 09:58:33 PM »
It is a 1/2 mile or maybe a little less. It's not bad until you are really moving like over 200 unless your brakes are" not so good". I would highly rec. a parachute(if you run a car that is).
E.C.T.A. 200 MPH club
221.4 mph at Maxton sept. 08
Offline tricktom1
« Reply #3 on: May 24, 2008, 02:32:27 PM »
it's supposed to be 1/2 mile. I've been 237 with no problem. I would not recommend that fast for a newbie though. They have a drive through before everything starts, I recommend that for sure.
TexasMile 261.5 MPH
http://www.houstonmile.com/
Offline TheRipler
    • http://www.landsharksti.com/
« Reply #4 on: September 10, 2008, 03:05:22 PM »
Just from rough guestimates on google earth, it's ~.5mi of good shutdown before the turnaround, and there's ~.2mi more of WWII era concrete if that's not enough. If you need more, there is a pasture. I would recommend stopping before you get to that.
Professor Weinburger sighed, knowing that without the alien mother to care for the last surviving egg of her once-proud species, the egg would surely die; still, he thought, greasing the fry-pan, it certainly was going to be an interesting breakfast.
Offline willieworld
« Reply #5 on: September 10, 2008, 03:43:56 PM »
http://www.airnav.com/airport/7T3            looks like they have 2 runways 8000 ft each ------            willie buchta
« Last Edit: September 10, 2008, 03:46:04 PM by willieworld »
willie-dpombatmir-buchta
« Reply #6 on: September 10, 2008, 05:27:10 PM »
The Race runway is a Standard Navy "bounce strip, to practice carrier landings" ---1000' of concrete on each end with 7000' of very smooth asphalt in between. the problem is you dont start at the outer edge of the concrete----have only seen pictures of start line.  But I checked it out in '99 when Govt. just turned it over to the county. Skip and I were looking for a test strip.
Offline Stainless Two
  • newest member of the 199.9 club :)
    • MySpace Page
« Reply #7 on: September 11, 2008, 12:23:30 AM »
It can get a little hairy on weak brakes.  I was getting high 180s and had to engine brake hard and full rear brake at the end for the lack of the front disks and rotors.  I tested the overrun area once as well :)
Standard brakes should not have any problems.
Look at my new RED HAT!!!!
#278 1000CC APS-G 208.959MPH record
209.093 mph best time
pit bitch to #1000 Bockscar
Proud to be a Texan!  in San Antonio
Offline willieworld
« Reply #8 on: September 11, 2008, 01:55:32 AM »
the faa says its 8000 ft-and on each end is 1000 ft of concrete leaving 6000 ft of pavement-----------------http://www.airnav.com/airport/7T3  ------------willie buchta
« Reply #9 on: September 11, 2008, 09:11:22 AM »
Willie---who you gona believe---the FAA of my senior memory!!!!!!!!!!  LOL thanks for setting the record straight---there is a 1000' of semi-packed gravel beyond the concrete.
