Author Topic: FWD motor to RWD car.  (Read 10985 times)
Offline doug odom
    • popmotorsports.com
« on: April 27, 2008, 04:10:45 PM »
Anyone have any experience installing a FWD ( sideways) motor to a inline configuration?
Doug Odom in big ditch
Re: FWD motor to RWD car.
« Reply #1 on: April 27, 2008, 05:50:39 PM »
I haven't, but seem to think it has been done by some of the street rod guys, but don't know where to send you,
Offline GeneF
« Reply #2 on: April 27, 2008, 06:16:48 PM »
If the motor was never offered in a rwd model from the factory, a custom bellhousing and/or adapter will have to be used. Try these guys:http://quad4rods.com/ What motor are you considering. Also, http://www.kennedyeng.com/ makes various adapters and custom clutch discs, which may help.
« Last Edit: April 27, 2008, 06:32:45 PM by GeneF »
Offline panic
    • My tech papers
« Reply #3 on: April 27, 2008, 06:51:13 PM »
Making the engine work is far more obvious and straightforward than from the bellhousing back.
What car, what motor?
Offline sockjohn
« Reply #4 on: April 27, 2008, 07:39:39 PM »
+ one on Kennedy.  If they don't make it, they most likely will do so on request.
I would post the motor and trans choice you are considering, as there are many who have "been there done that" on this.
I've seen several GM Ecotech engines in RWD cars, so I'm guessing that is an "off the shelf" solution
Offline GeneF
« Reply #5 on: April 27, 2008, 07:50:06 PM »
 The Ecotech became a real easy rwd option over the last 2-3 yrs. as both the Solstice/Sky are Eco w/rwd.
Offline doug odom
« Reply #6 on: April 27, 2008, 07:59:44 PM »
Sorry, Its a Nissan V6 VQ30DE to a Liberty trans with a Chevy 23 spline input shaft. They put that motor in the 350Z rwd but the bellhousing is part of the transmission like most imports. I'm making a pattern of the back of the motor and think I will have to use up an old Lakewood and weld the adapter to it.
Offline maguromic
« Reply #7 on: April 27, 2008, 08:38:58 PM »
Couldn't you run a mid plate at the back of the motor and bolt any bell housing to it?  Thats what I did for my Jimmy to run a Liberty box.  If you are worried about the impute shaft Liberty can make you one in any length and spline you want or might even have one off the shelf.
Offline RichFox
« Reply #8 on: April 27, 2008, 08:54:12 PM »
When I put the 30E in Jacks streamliner I used a SBC Lakewood blowshield. I set the block on end on my mill and maped the hole locations from the rear main centerline. Then I set up the Blow shield on bearing retainer hole and drilled it. As i remember all the holes worked out. Maybe I drilled the block plate. I should have the hole locations around here some where. Don't know if your block is the same as mine. Want some 30Es?   RF
Offline jauguston
« Reply #9 on: April 28, 2008, 11:56:08 AM »
Probably no help for what you are doing but I have a VW 1.6 turbo diesel in my Suzuki Samurai. Acmeadapters make a conversion kit to install most any VW gas or diesel onto a Samurai or Tracker/Kick transmission. It is a bolt in no welding swap.
Jim
Offline RichFox
« Reply #10 on: April 28, 2008, 12:09:18 PM »
PS The first motor came from a Z car. The second one came from  Maxima which I think is a sidewinder FWD car. Seemed to be pretty much the same for what I wanted.
Offline JimL
Re: FWD motor to RWD car....another way to do it.
« Reply #11 on: April 29, 2008, 01:59:27 AM »
When Dan Wagner and I put together the 797 car, we put a 1/4" steel plate on the back of the engine, cut 3/4" thick blocks (threaded) that were bolted to the bellhousing, stood the engine on it's nose, and lowered the trans/input shaft into the pilot bearing.  The MIG welder stuck the blocks to the plate, and the trans would bolt on/off.
Why did it work?....because the Getrag had a little less than an inch of shaft sticking out!  With that in mind, here's one tranny setup that will work:
The Tacoma V6 5 speed (1995-2003) has a reasonable 4-5 gear spread.  The 4Runner/Truck 5 speed (1988-1994) has the same basic trans, but the input shaft and bell housing are 1 1/8" shorter.  That means you can use the "short" early V6 bell housing on the Taco V6 trans and have 1 1/8" of shaft sticking out.  That is 3 sheets of 3/8" aluminum or steel...one sheet to bolt to the engine, one to the bell housing, and one to connect the two together.  You've just adapted a 5-speed to whatever you want....with a bandsaw and a drill press.
It also moves the clutch release fork to the right side of the bell housing, which really helps the tight cockpit in a roadster or whatever.
If you need a bigger Overdrive (20%), use the Supra Turbo 5-speed (1986-1992).  It takes the early truck V6 housing, and has the same input shaft length as the Tacoma V6.  The pic below shows the Supra trans with the early V6 bell housing (for mounting to the V6).  I made the spacers to get a bell housing with clutch fork on the right side (we put a supercharged Taco V6 in a 1978 Corolla).
Clutch disc for these trannies are available from several suppliers, with "grippy" stuff to take the power.  On the dragstrip, these transmissions would go most of a season at the 500 HP level, in 3000 lb vehicles on slicks.....probably good enough.  Pretty cheap part in the junkyards, these days.
I don't know of other transmissions with bolt on bell housings (in different lengths), but maybe someone else has an idea.
Regards, JimL
Offline JimL
Re: FWD motor to RWD car....follow up...
« Reply #12 on: April 29, 2008, 02:06:00 AM »
Just to clarify....about the pic.  If you take the 3 pieces of aluminum out, the bell housing fits to the case, and 1 1/8" is now sticking past the bell housing.  Sometimes I don't make sense....and most of the times I don't make cents!
The rest of the times is just a blur.
« Reply #13 on: April 29, 2008, 09:29:43 AM »
Jim that is some good stuff there.  Is 1 1/8 inches what you normally need sticking out to make things work?
Harv has adapted a Mazda 2200 transmission to a 1.9 Saturn engine.....
........... the rest is here..........
http://purplesagetradingpost.com/sumner/harvey/construction%20page-6.html
.......... and here........
http://purplesagetradingpost.com/sumner/harvey/construction%20page-7.html
c ya,
« Reply #14 on: April 29, 2008, 12:41:43 PM »
Just becasue it give me a chance to show some picture of my car, I put a Ford Zetec from an Escort fwd car into my 28 roadster and used a Ford/BW T-5 tranny. Got the bell housing from Quad 4 rods in Denver. Even with this "ready to use" bell housing I did alot of fitting and changing. It is most important to make sure that when the tranny is bolted to the motor that the pilot end of the input shaft is the right depth into the bearing and that there is plenty of room for the throw out set up and that it is a straight fit into the pilot bearing.
I have built a couple of adaptors before and obviously the most important things are alignment between the throw out bearing and the tranny and that the surface that mounts to the engine and the surface that mounts to the tranny are parallel.
