Author Topic: Roadster front vs rear track  (Read 1601 times)
Offline maguromic
« on: April 26, 2008, 11:35:48 PM »
I know the wheel distance from the body has been hashed out here, but what about the front wheels on a roadster and the effect it has on the body?
I was playing around doing some cad modeling of a roadster and just got me curious at the front track versus the rear track.  If you look at the top view of the cad model, it clearly shows the body is in the path of the wake from the front tires.  When this air collides with the other air flowing down the sides it must do some negative things to the flow causing drag.  Am I correct in this assumption or off base?
So what if you moved out the front wheels from the minimum 44” to 50-52”.  Will this have a positive effect on the airflow to cut down drag? Like to hear the pros and cons of my theory.
Re: Roadster front vs rear track
« Reply #1 on: April 27, 2008, 12:28:08 AM »
If it was me I would try them out like you suggested and the rears in and as far back as the rules allow.  If it is a modified where you can streamline ahead of the cowl (that's right I think) I would think about even trying a lip right ahead of the cowl to try and devirt the air out just enough to maybe get it past the rear tires/wheels.  Might not be possible.
In the attached picture Blowfish has a small lip on the front of the wheelwheel that deflects the air out enough to get it past the wheel opening before it comes back to the body.  Of course they had wind tunnel time to perfect this.
c ya,
