May 19, 2013, 09:30:54 PM *
Pages: [1]   Go Down
Author Topic: Carb questions, please help  (Read 1603 times)
Clay Pitkin
« on: April 26, 2008, 05:58:43 PM »
Hi guys,
I am getting ready to install a set of 3 Mikuni TM flatslide 40 MM carbs.  The throttle cables coming from all 3 carbs go into one main coupler so that coming from the gas pedal you only need one cable instead of 3 for indivdual cables.
I have another rack of carbs 36 MM that are all on one rack. there is a rail that holds them all together, including a piece for a throttle cable to fit on.
My question is do I need the rack for the 40 mm's or can they run on the engine individually?
Also is there any where I can get a diagram or pic of a finished carb so that I know what goes where etc?
TIA
Clay
fwillyj
« Reply #1 on: April 26, 2008, 09:31:26 PM »
-I did a    40mm carburetor exploded view    search on google on this link below was one of the choices---maybe it's what you want.
http://www.carbparts.com/mikuni/vm20_44.gif
ol38y
When all else fails, gas it!
« Reply #2 on: April 26, 2008, 09:57:46 PM »
Mikuni's website only shows 1 TM flatslide. It's a 33 pumper. You might look at the HSR carbs. They're flat slides for Harleys. Thay might help you as well.
http://www.mikuni.com/pdf/tm33.pdf
Larry Cason
2010 BUB 1350 M-PG record
« Reply #3 on: April 27, 2008, 10:28:19 AM »
3 carbs and 3 cables will be hard to keep in sync.  Don't know your installation, but a common throttle shaft would be best.
 MSA Lakester #1000 my fastest mile 245 and change, 84 ci turbobusa motor... but Corey's 233 MPH H/BFL record is still 3MPH faster than mine.
 Builder of Bike 278 1000cc APS-G,  Kids Red Hat Record 208.959 (old PS rules)
 Other kids A-G record 179.172  Josh O record 182.266
 Co-owner of the Amo Steele Streamliner, #1411... still sorting
Pages: [1]   Go Up
Google visited last this page May 18, 2013, 02:52:11 AM
