Today I got around to welding the other tube together, same material, same rod, same heat. The difference was after I finished welding it, the weld cooled I took the torch and heated the chrome moly from the weld to about 1 inch out to a dull red. When that cooled I took it to the press and put the squeeze on it. As you can see from the pictures I took it out of the press a couple of times and took some pics. The first pics you'll see the metal starting to distort. The second set you'll see the cracks starting. And then the third set you'll see the metal with a good tear.As you can see in the pics the chrome moly held together longer and the mild steel distorted much more in the second test then in the first. But, I can tell you this, the first test took much more pressure to break the tubing than the second test. The first test the tubing distorted a certain amount and then just ripped. The second test the tubing bent and distorted much more before it ripped, but it took alot less pressure from the press to do it. So my conclusion other than my second weld held flawlessly, was that if you don't heat it after you weld it, its much stronger but more brittle. If you heat it after you weld it the chrome moly acts much more like mild steel would. My personal preference is mild steel. Availability, cost, easier to bend, easier to weld. If I was going to use chrome moly in a door car I wouldn't heat it after welding. But if it was a dragster or an altered or a motorcycle chasis and it was chrome moly I would heat it after I welded it. But look at the pics and make up your own mind. I hope that I have helped someone out there.
Willie Buchta
