Author Topic: Will VP gas pass tech?  (Read 6831 times)
Offline isiahstites
« on: April 07, 2008, 12:21:23 AM »
Curious if anyone can tell me if VP's c12 gas would pass inspection if I set a record at El Mirage?
I have looked all over Scta-Bni's website and can not find anything .
Scott
Offline bvillercr
Re: Will VP gas pass tech?
« Reply #1 on: April 07, 2008, 12:49:30 AM »
I thought if your in a gas class it didn't matter what gas you ran, as long as it was not some sort of fuel.  PM Dan Warner or some of the tech guys to make sure.
« Last Edit: April 28, 2008, 11:16:33 AM by bvillercr »
Offline Nortonist 592
    • http://www.artfv.com/design/fashion/
« Reply #2 on: April 07, 2008, 01:09:50 AM »
I read somewhere (and for the life of me I can't remember where) that C12 is a legal gas for El Mirage.  Did the SCTA get a new "analyzer"?
Offline isiahstites
« Reply #3 on: April 07, 2008, 01:12:49 AM »
I just want to make sure that it is alright. I would hate to finally get to impound only to have my gas fail the test.
Scott
Offline mike mendoza
« Reply #4 on: April 07, 2008, 02:08:30 AM »
Scott
waiting   for   answer     mez
Offline Dean Los Angeles
« Reply #5 on: April 07, 2008, 09:35:21 AM »
Have the gas tested before you run. Take your fuel to tech inspection and they can check it for you. If it doesn't pass you can buy gas from George Callaway.
Offline speediesparks
« Reply #6 on: April 07, 2008, 10:40:36 AM »
  Give Fogy a call.He has a list that shows the numbers for the gases available and if they are OK to run.
 :-D
Just counting the days to go racing!
Offline ol38y
« Reply #7 on: April 07, 2008, 11:39:49 AM »
http://www.ridgecrest.ca.us/~hideseng/dc_list.htm
This was posted in a previous thread but I don't remember by who.
Larry
Larry Cason
2010 BUB 1350 M-PG record
Offline isiahstites
« Reply #8 on: April 07, 2008, 08:49:15 PM »
Larry
Ok, so what do the + / - numbers mean?
Scott
racin jason
« Reply #9 on: April 07, 2008, 10:55:21 PM »
i ran and tested c-16 and it was way under the max number.
Offline Mac
« Reply #10 on: April 27, 2008, 06:48:51 PM »
Hi,
We ran VP C16 last year at El Mirage too and it passed tech when we set a record.
Miriam
Offline fastesthonda_jim
  • Ready to Rock 2003
« Reply #11 on: April 27, 2008, 11:49:05 PM »
The web site posted lists the Dielectric Constants for most gasolines.
C-16 is a sort of "standard" in that it comes in on the meter darn close to 0.0, pretty much no sweat when the old rule called for DC's less than 2.3
But now if you go down to Circle K or 76 and buy 91 octane, it will read between 5.5 and 7.0+/-.  What?  You can't run pump gas as "gas"?  So in mid stream last year the D/C limit was bumped to 6.0 to allow for "modern" gasolines.
Because many pump gasolines were still outside the limit, and because of some questioning by some of us who want to run "hotter" gasolines and the difficulty in establishing just what exactly is a "gasoline", the rules committee met, and after some long discussions with Rick Gold of ERC, decided that in the future, gasoline was anything with a D.C. less than 15.0 (see the new Blue Book, the one with an SDRC bike and an SDRC car on the cover, for the new rule).
So, yes, your C-12 at -0.5 certainly looks like it will qualify.
Jim
2006 SCTA High Points Champeen
2006 Dirty "2" Wrench Of The Year
Bonneville "2" Club 2003
El Mirage Dirty "2"'s 2006
Bonneville Records: G/GS, F/GS (Boy)  G/FS (Girl)
El Mirage Records: F/BFS, F/FS, F/GS, I/FS, I/GS, K/BGS
FIA Records A, II, 8
Unlimited License
300mph line qualified (305.129 best mile speed)
The older half of San Diego's Fastest Couple
2016 Man of Distinction Award
DLRA 2019 Top Speed of The Meet (309.438 Mile - 323.3 GPS)
Offline isiahstites
« Reply #12 on: April 27, 2008, 11:55:22 PM »
Thanks for the explination Jim, see you in May!
Scott
Offline donpearsall
    • http://soundappraisal.com
« Reply #13 on: April 28, 2008, 01:19:24 AM »
Just so it is clear to me, if you run a gas class at El Mirage, you do NOT have to buy gas there and have your tank sealed (like Speedweek)? You just run whatever is in your tank and have it tested if you break a record?
Thanks
Offline isiahstites
« Reply #14 on: April 28, 2008, 01:24:29 AM »
Thanks
Yep
