Hey Sum,
Yeah, his house could best be described as a "trip".
Off the subject but a good story. Dan had a coming out, or birthday party when he finished his first version of the '32. Party was on his front lawn. His garage door was open but the openning was papered over. Dan got in his fire suit and as I remember his helmet, fired up the engine, drove thru the paper and up the block. In making the U-turn the engine died and we had to push him home. Great fun!
Back on point:
Mike, I was just outside doing some glass work and thought of a few more hints.
I noted briefly how weather affects how the resin kicks. Today it's cloudy and cool here. Probably much the same up your way. Temprature and humidity both affect the working life of a batch of resin, and how long it takes to set. Today it's about 60 degrees so I used about 18 drops of catalyst per ounce of resin and it kicked at about 15 minutes while remaining a little tacky before finally setting hard. At 80 degrees I would probably have used a ratio of 10 drops. Sometines on cooler days it seems like the resin will never kick, but eventually it will.
One thing I learned the hard way is that applying polyester resin over epoxy resin doesn't work. The polyester resin will not set, even with a lot of heat.
The thing I forgot to mention is to have fun with it! Some really complex shapes can be made using internal /external molds and or HD foam. It's easy to cut, grind and sand.
Another quick story. Back in the late '60's local Drag Racer Randy Walls rented a '69 Nova for the weekend. As the story goes he used modeling clay to fill all the seams, waxed everything up good and made a mold for his Funny Car. Cleaned up the Nova and took it back with no one the wiser.
