Author Topic: Front end alignment on fabbed front ends….hows it done?  (Read 9732 times)
Offline V4F STR 60
    • Montana Dodge Boys Fast Four Special
Re: Front end alignment on fabbed front ends….hows it done?
« Reply #15 on: September 04, 2008, 10:15:56 AM »
Good morning,
Thanks to all for your input.   Here's what I discovered in the last week.  Car had ALOT of Ackerman, too much positive scrub, and some rack-induced movement in the shackles.  The bump steer is negligible (almost nonexistent) throughout the range of suspension travel.
Going back together today with new steering arms (very little Ackerman) and a shackle-less spring mount on the drivers side.  Still searching for the correct hub/wheel combo for the scrub radius.
I'll try the water trick when it's all back together and keep you posted.
Thanks again, Pedro
Godspeed Cliff Gullett.
1928 Dodge Brothers Vintage Flathead Four Cylinder Roadster & Lakester
Landspeed Records
Bonneville
2009 V4F/STR 115.681
2009 V4F/GR 116.439
2009 V4F/FR 117.597
2010 V4F/BSTR 127.352
2012 V4F/BFMR 130.843
2013 V4F/BGMR 142.956
2013 V4F/BFMR 143.254
2013 V4F/BGR 138.395
2013 V4F/BFR 138.984
El Mirage
2016 V4F/BGMR 140.961
www.facebook.com/MontanaDodgeBoys
www.fastfourspecial.com
