Author Topic: Ford 8 inch rear  (Read 12175 times)
Offline Dave Haller
Ford 8 inch rear
« on: February 18, 2004, 10:20:00 PM »
Anybody out there using a Ford 8 inch at BVille? What kind of gear can you get for it? Will it handle big horsepower?
 Thanks for any input,
 Dave Haller #93
fwilly
Re: Ford 8 inch rear
« Reply #1 on: February 19, 2004, 08:21:00 PM »
-are you talking about something like what the 4cylinder Pinto of the mid 70's?
 -We've run them in a G/fmr but thats not a lot of HP but the one problem we've had is the gear ratios are not easy to get a good variety.
 -something like 4.62 then 4.10 then 3.80 with nothing in between.
 -I don't see any reason to run an 8" where you'd be putting a lot of power to'm with an expensive engine when you can a 9" and we all know they'll take about anything you can dish out.
Cal
« Reply #2 on: February 20, 2004, 01:11:00 PM »
Actually, the Ford 8 inch is supposed to be almost as strong as the 9 inch and should have a lot of gears available for it, though not as many as for a 9 inch.  This is not the same rear that was used in the 4 cyl Pinto; this is a newer design that is used in the Ford Mustang amoung others.  I think it is also more efficient at transmitting power.  Having said that, I sure like my 9 inch Ford rear.  I think either one would work fine for you at BVille.
Offline jimmy six
« Reply #3 on: February 20, 2004, 01:59:00 PM »
Jack Kelly with the 644 lakester uses one with his D and E gas Chevies been 240. He's not happy with the slection of gears. not many available for LSR.
Offline Dave Haller
« Reply #4 on: February 20, 2004, 10:38:00 PM »
Thanks you guys. Good info. I run a narrowed nine in my Beretta that has worked just fine. A friend suggested the smaller eight due to smaller size and weight. I don't think the gear choices would work as well as the nine. I'm starting a new lakster project and am in the planning stages. Thanks again,
 Dave Haller #93 C/GAlt
Offline bigtim44
  • NaCl addict
« Reply #5 on: February 21, 2004, 10:44:00 PM »
There's a guy down in Denver CO. he's is a 8 and 9 inch guru,he told me that some cars from the 60's came with a 2:26 (rare...chickens back teeth) and some came with 2:35(rare but not too bad to find)
Salty Box Racing #622 B/DT
wmtsmith
« Reply #6 on: February 22, 2004, 09:32:00 PM »
Dave,
 Caddy has a 8 7/8 with selections from 2.28 up
 Gm 8.5" starts from 2.41
 Gm 7" from 2.14
 With all GM's about 4% more power gets to the ground than with a ford -- of course the down side is ratio changes and c clip eliminators required
nitrousvette85
« Reply #7 on: April 13, 2004, 12:05:00 PM »
hey Sparky, On the plus side those old GM rears can be had for free in many cases if you're willing to take the whole car and junk what's left LOL
Offline John Burk
« Reply #8 on: April 13, 2004, 04:19:00 PM »
A Strange dropout 12 bolt or dropout 8.8 (ford)gives the benefits of a 9" with more efficient gears . Does anybody know who made the deal that allowed 12 bolt gears to bolt into a 9" center section . I think it used a custom spool and a custom pinion carrier that moved the pinion upward .
Offline John Burk
« Reply #9 on: April 13, 2004, 04:20:00 PM »
Offline RICK
« Reply #10 on: April 15, 2004, 08:37:00 AM »
Offline RICK
« Reply #11 on: April 15, 2004, 08:43:00 AM »
Mark williams @1-800-525-1963, or www.markwilliams.com makes the diff you seek.
