Author Topic: El Mo 350 Sidecar record? Why 250cc?  (Read 3439 times)
Offline Carl Johansson
« on: March 31, 2008, 03:59:22 PM »
So I was just perusing my new rule book.  in the el mo records for 350 cc motorcycle -  sidecar Gas
it liststhe Burns Yamaha 250 with a record of 126 and change (set in 99) .  It also lists the Burns Yamaha 250 at 128 & change also set in 99 in the 250 class sidecar.
Did they change something internally on the engine?  They must have because as I read it 7.B:13 would exclude a record set by a MC with displacement smaller that max allowable for the next lower class.  So where am I missing this?
Carl Johansson
Carl Johansson
 Auberry Ca
racin jason
Re: El Mo 350 Sidecar record? Why 250cc?
« Reply #1 on: March 31, 2008, 05:38:36 PM »
bored out 1mm?
« Reply #2 on: March 31, 2008, 05:42:00 PM »
2006 rulebook shows them in the 250 cc records.
The SCTA web site shows them in the 250 cc records.
Looks like a rulebook typo between then & now?
Offline ol38y
« Reply #3 on: March 31, 2008, 05:48:04 PM »
bored out 1mm?
That was my first thought. On the old 2 stroke twins, all that was required was changing the pistons and barrels.
Larry Cason
2010 BUB 1350 M-PG record
Offline RX7Paula
« Reply #4 on: March 31, 2008, 06:23:58 PM »
My pop ran both motors in the sidecar in 1999, 250cc amd 350cc.  He actually had 3 of the exact same bikes, set up in different configurations.  The 350cc record he set in October 1999 actually had to be certified at his memorial as he passed away just days after setting this record.
Paula Burns
Driver #203 - Callaway Roadster
Paula Burns
Offline mike mendoza
« Reply #5 on: March 31, 2008, 11:47:27 PM »
   Just shows us the powers to be.   God Speed  Mike
dwarner
« Reply #6 on: April 01, 2008, 09:08:59 AM »
You can't get a more personal than that.
Thanks Paula,
BTW, in case you guys are not aware Paula is George Callaway's driver. She won the El Mirage Championship in 2006(?). Another case of the LSR kid not falling far from the tree.
