Author Topic: Nomograph relating CdA, BHP and MPH  (Read 28506 times)
Offline sockjohn
Re: Nomograph relating CdA, BHP and MPH
« Reply #15 on: June 04, 2008, 05:47:08 PM »
How do you figure what your coefficient of drag is?
Scott
Pay your bucks to the wind tunnel or do a roll down test.  I believe Jack D has experience in doing roll down tests.
I would have to dust off a book or two or do a bit of googling, so you may see what you can find on roll down tests.  In theory it's supposed to be easy IIRC.
Offline tortoise
« Reply #16 on: June 04, 2008, 06:34:18 PM »
Uh, see "Coast Down Formula", in "Formulas", this site.
« Last Edit: June 04, 2008, 07:39:20 PM by tortoise »
« Reply #17 on: June 04, 2008, 09:56:03 PM »
Jack started his tests at the local bowling alley -- and progressed to engineering wonders.
Offline comp
« Reply #18 on: July 07, 2008, 08:24:45 PM »
There is some good info on wind tunnel testing at
www.A2WT.com
 cool link
Offline ronwoo
« Reply #19 on: February 06, 2012, 02:32:20 PM »
Hello, I just went to open the nomograph, one of my favorite things, and it appears the link is broken. Is there another way I can get access to it?
Thanks, Ralph Hudson
Offline Hot Rod Lincoln
  • F/GC Record Holder 164.845
« Reply #20 on: May 17, 2012, 05:43:21 PM »
I was wondering the same thing?
Is there another calculator to use that has the cd numbers?
Jon
« Last Edit: May 17, 2012, 05:45:36 PM by Hot Rod Lincoln »
Offline hotrod
    • Black Horse photo
« Reply #21 on: May 17, 2012, 06:55:37 PM »
I suspect this may be an issue the web elf needs to sort out, the link might have gotten broken when they did the upgrade.
Larry
Offline ol38y
« Reply #22 on: May 17, 2012, 11:58:42 PM »
The RB Racing link in #5 still works...
Larry Cason
2010 BUB 1350 M-PG record
