Sumner-I am very limited on gear choices with this car. I have the tallest final drive that I can find in the car and there are only 2 usable 5th gears(I'll be bring both with as it is very easy to change 5th gear, we can do it with the trans. still in the car).
There are 1 or 2 other 5th gears available but they make the gear split too great. As it is when I shift from 4th to fifth it will drop down to approx. 7,200-7,300 rpm which is right at the torque peak with the smaller turbo that I had last year. I will probably also be bringing at least 2 different turbo with and try to balance the cars performance with them also. I will probably start out with the smallest one !
I would like it if I could get a set of tires that would be like 26.5" tall but oh well.
One thing you have going for you with the turbo and gear split is they like a load.
If you are going to run Speed Week don't forget the limited runs when thinking about switching things around. I would suggest going with what you think might be the most middle of the road package that you could get more or less aggressive with if needed. If you decide on a class I would try and maximize to run say 5 mph over the record unless the record is really soft. Try not and get too greedy, you can do that after you own the record
. The other meets are also somewhat limited as they don't run as many days and often "weather out" and come up short.
Is the motor still a G motor or bored/stroked?? and a F motor. The G comp coupe, altered coupe and blown gas coupe all look very doable and most of those in the fuel classes look the same. If you are now F then I would look at the blown gas coupe class and maybe forgo the other two for now.
I think your weight might be fine with the all wheel drive, but you could be right on the edge, so taking some is a good plan. Is the weight now about 50/50?? GH is collecting wheel weights at a couple tire places that he will melt down I believe. Personally I'm not crazy about messing with molten metals. I think Speed Way sell lead weight and if you still can't find any Phil (RustyT) on here bought some and maybe he will post or I could check with him and let you know.
c ya,
