Author Topic: BB Bonneville Bugeye  (Read 147306 times)
Re: BB Bonneville Bugeye
« Reply #120 on: February 23, 2010, 12:09:28 PM »
Udo,
I know what you mean about fiberglass, I cannot work with it without getting it all over me and anything close. I watched one of the very best fiber glass guys that ever made a glass part, Wayne Hartman, make a fender mold once and he never got resin above the first joint on his fingers! never broke a sweat, never got anything on his shirt or pants! By shear luck I do remember some of his methods but never was able to be as "neat" as he was.
I know your mold will turn out good parts, it may take some sweat and swearing but my guess is that they will look great. As my favorite saying goes, "When you learn by experience the test comes first and the lesson comes afterward."
Offline Rob
« Reply #121 on: February 25, 2010, 04:26:18 AM »
You could always join the two halves again once out of the mold, there by losing the join line completely.
Cheers,
Rob
Offline hotschue
« Reply #122 on: February 25, 2010, 05:39:58 PM »
Thanks Rob, That's certainly an option.  The air intake will be located in the nose as well as the intercooler.  Two halves would give us access, although one piece would look slick.  Will consider both options once I have parts in hand.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
« Reply #123 on: February 26, 2010, 01:00:08 AM »
Udo,
Are you planning to run an air to air intercooler?
Offline hotschue
« Reply #124 on: February 26, 2010, 09:14:40 AM »
Rex, Yes, we've run air to air with the 2 liter good results.  Air intake will be on the leading edge of the nose.  We're going to try several designs.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline jacksoni
« Reply #125 on: February 26, 2010, 12:03:43 PM »
Hmmm, engine guy and car guy not communicating well. I think is air to water intercooler.  :cheers:
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #126 on: February 26, 2010, 12:09:55 PM »
Udo,
Look in one of Carol Smith's books, I think it is Engineer to Win, and there are some parameters on doing inlets and ducts for coolers, if you do it right it can actually provide some additional thrust. This is because the heat exchanger adds heat (energy) to the air. I am not a big fan of air to air coolers on Bonneville cars, air to water I think is easier and more efficient but if you do the air to air you can at least cancel or greatly reduce the drag of the air going thru the cooler if you do the ducts right.
Offline hotschue
« Reply #127 on: February 26, 2010, 01:44:14 PM »
Rex, I stand corrected..... air to water......what was I thinking....to much bondo dust!!!
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #128 on: March 14, 2010, 08:02:19 PM »
Plug finally DONE ready for gelcoat and fab mold.....more hours/material than I ever imagined.  Plan to fab mold midweek weather permitting then fab actual nose....
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #129 on: March 20, 2010, 08:46:40 PM »
Need to make a transition from full belly pan to rear body panel.  In my spare time.... how many days to August?....I figured I'd start to tack weld the the bottom pieces while I was waiting for the fiberglass/bondo to dry....never a dull moment!  Couple of pics then back to nose plug....
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #130 on: March 24, 2010, 07:18:15 AM »
Finalizing the nose cone....pic shows gelcoat.... the first coat of fiberglass mat....then reinforcement to keep mold from distorting.......yesterday attempted to remove plug from the new mold....obviously the release agent didn't quite work....had to dig it out, what a mess....mold turned out very well and thats what counts!!!!....this morning we will prepare mold to make the nose cone.....finally it was a long road!
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #131 on: March 24, 2010, 07:20:10 AM »
This is the actual mold....
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
« Reply #132 on: March 24, 2010, 08:52:15 AM »
The mold looks great Udo. Good luck with the actual piece.
Is that an Allard in the background? I'd be interested in hearing a little about that car.
Offline jacksoni
« Reply #133 on: March 24, 2010, 05:18:43 PM »
It is. Nice pick up.  Hemi powered.  Friend of Udo's and he might give some additional info.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline lvsalt
    • http://www.dcwaterjet.com
« Reply #134 on: March 24, 2010, 07:55:32 PM »
looks GREAT, I know of a Z car that could use something like that :cheers:
Gary Cole     DCWATERJET Z
