Sumner, I have an SFI flexplate shield from when I ran a powerglide that you can have, let me know and I will box it up and send it to you. Cya
Thanks and I think Hooley said he might have a blanket, but you guys hold off a little while. I hope to have the parts for my new motor back from the machinist the end of this week or next and when I put the new motor in I can check for clearance and see if that stuff is going to fit, especially when I later put in the 4L80E I've had rebuilt. I talked to some of the tech guys at El Mirage and I might just have to plate that area with 1/4 inch plate to make everything fit.
I'll be talking to you and if I need it I could get it on my way to Maxton in May. I was planning on seeing you then anyway,
BTW the sun is out here and getting warmer, heard you guys got an ice strom again ............... Blanding looking better??
