Rich, if I could do photos, I would post some of the GMC. The intake is a log type using 3" OD stainless steel with runners 2" OD with 2 injectors per port with a 75 mm throttle body attached. Soft records, sounds like it, but one never knows, sure is a lot that can and will go wrong. After 7 trips to the salt I have increased speed from 207 to 234, many hours of work and lots of $$$$$$$$$$$$$$$. Sum we went to the chassis dyno on Monday, ran real good and Scott got to tune it in the upper range of rpm and boost. Drove home yesterday from Omaha, Nebraska in blowing snow.
