Thank you everyone for your input, I will certainly take all your feedback on board.
My original intention for running is not set a motorcycle land speed record but to beat the records set by the vespa and Lambretta motorscooter manufacturers in the 1950's , under their definition of a motorscooter as a two wheeled vehicle with rim diameter of 10", total capacity of 125c.c and a direct drive transmision ,built directly off the engine cases. But do to the fact that those records were set independently and under no restrictions of safety regulations to build a similar vehicle today, I would not be allowed to run.
Therefore I have decided to continue and attempt to build something using the current regulations.
I am attempting to base a design around my body build which I believe will aid in such a small capacity machine. I am only 5 feet 4 inches tall, and weigh approximately 55kilos.
I sat down last night placed a helmet on my head and with the aid of my trusty camera proceded to take a few snaps of different positions, before I read these replies and figured out that if length is not really a factor laying on your back feet forward would be the lowest possible position you could attain, even lower than head first due to the vision restricions of a helmet. is length really not as big of a concern?
i still did not come to any conclusions on which will be best for what i want to do .
If I decided to go with the kneeled Kreidler position , would this be acceptable today, or have we already confirmed that as long as you are indeed strapped in it will pass current regulation.?
yep bones its Nate I guess after swinging off of roadracing LCR sidecars I just don't want to be a strapped in and can't shake the box monocoque designs
