Center hub, leading link, trailing link, spindle, king pin... they'll all work if designed properly...
Terry,
You have one major problem with your design... "King pin inclination".... as your suspension moves your kingpin angle changes..You indicate on your drawing of a static 18deg (too steep for 300mph) as the suspension moves upward your planned 1.12"of travel, you will probably be at 8 to 10 deg. To fix this you have 3 options.
1) You need to float the kingpin and have a drag link anchored vertical from the swing arm pivot (I have ideas as how to do this) but your 12deg of turning might pose a problem with drag link to tire contact
2) 2 swing arms (I can take a pix of the setup that’s on one of my liners)
3) No suspension (it might actually have some benefits)
whatever design you choose you should probably change it to a leading link style especially if it is of a single sided design due to thickness for support at curve and to get tire clearance. Usually my tires rub the bodywork right about where you plan to have your swing arm run.. You will be able to narrow up the front CD if you do
Willie
I have a couple of center hubs and front suspension designs I can loan you to copy. You should come down and take a look.. all my designs are for 300+mph and use a 15” rim for the Goodyear 21-3.5X15 LSR tire
