Steering stops are designed to limit the handle bar swing so you don't mash your hand off the grip, and almost everybody knows it.
That is the rule using common sense, and can be written as such, and easily verified.
If you are underway and your steering exceeds even fewer degrees, you are in a tank slapper that often results in a get off, or you already have.
The 15 degree declaration misses the mark.
