Author Topic: Fireproofing the cockpit  (Read 1907 times)
Offline Loose Goose-Terry#1
  • Terry
  • When in doubt, GAS IT!
« on: November 05, 2007, 11:40:34 AM »
 :? When designing the stearing/handlebar for my streamliner, can I use standard rubber motorcycle handlebar grips? Or is it required to be fireproof or no handlebar grips at all?
 :? How about the seat covering and rollbar covering? Does even the foam inside the cover around the rollbar padding have to be fireproof too?
If you must error, error on the side of safety.
Terry
Offline Carl Johansson
Re: Fireproofing the cockpit
« Reply #1 on: November 06, 2007, 12:56:26 PM »
Rollbar padding must be SFI.  it's alot harder than the old foam stuff.
Can't tell you about the other stuff -  I don't think there is a specific requirement -  but don't knowq for sure!
Carl Johansson
Carl Johansson
 Auberry Ca
