Jim, paraphrasing what Stainless said, I usually put a strip of duct tape on the radiator where the vast majority of the salt off the front wheel gets collected. Remove the salty tape after a run, put on a new strip -- the radiator stays pretty clean and functional.
As you learn things about land speed racing you'll become quite familiar with the line that "Duct tape is your friend".
Or, the line saying that all you need is WD-40 and duct tape. If it moves and it shouldn't move, use duct tape. Vice-versa, if it doesn't move and it should -- use the WD-40. There you have it -- 90% of your problems will be solved if you remember that dictum.
