Author Topic: not just another wheel on a stick  (Read 89429 times)
Offline sheribuchta
Re: not just another wheel on a stick
« Reply #150 on: April 09, 2008, 11:48:58 PM »
a couple of more pics...
Sheri
Offline John Noonan
« Reply #151 on: April 10, 2008, 12:56:07 AM »
Looks like a stock piston..
J
Offline sheribuchta
« Reply #152 on: April 10, 2008, 01:20:41 AM »
looks can be decieving   8-)
Sheri
Offline John Noonan
« Reply #153 on: April 10, 2008, 01:22:46 AM »
Sheri
No,
It is a "Stock OEM piston".. :mrgreen:
Offline V8Pinto
« Reply #154 on: April 23, 2008, 10:19:16 PM »
Sheri that picture of you washing the cylinder in the sink made me smile from ear to ear!
I'm gonna show my friends what kind of folks we met land speed racing - this is the greatest!
We're looking forward to seeing you all.
Shane
V8 Pinto on juice
Hayabusa on the brain
Twin-Turbo F150 4x4
Offline willieworld
« Reply #155 on: April 24, 2008, 12:43:33 AM »
Well tommorrow is the day...
Went and got the gas today and tested all the lines. Tommorrow we will fire her up... :-o
Sheri Buchta
willie-dpombatmir-buchta
Offline willieworld
« Reply #156 on: April 28, 2008, 12:21:35 AM »
wooo hooo.....
She's all done and ready to race....Took some pics.
Damn Willie does good work. 8-)
Sheri Buchta
Offline willieworld
« Reply #157 on: April 28, 2008, 12:25:17 AM »
Sheri Buchta
Offline isiahstites
« Reply #158 on: April 28, 2008, 01:12:56 AM »
Nice gas tank!
Offline willieworld
« Reply #159 on: April 28, 2008, 10:49:33 AM »
i built it on 11-27-07 (posted on sheris build diary) when we were going to do some streamlining  but arnt going to have time before may  maybe later  willie buchta
« Last Edit: April 28, 2008, 10:59:20 AM by willieworld »
Offline V8Pinto
« Reply #160 on: April 28, 2008, 01:07:34 PM »
Willie that bike is the sh1t!!!
Shane
V8 Pinto on juice
Twin-Turbo F150 4x4
Offline willieworld
« Reply #161 on: May 04, 2008, 01:41:31 AM »
Well the blast is done, and as promised, we kept a cost sheet for the build. So here it is....
Willie and Sheri Buchta
Cost Sheet for the Blast sidecar #349
We bought a complete bike for 1300.00 and we sold 500.00 of parts off of it and we still have about 200.00 worth of parts that we still have to sell. Anybody needs anything let us know.
Engine off of Blast                          600.00
Material for the frame                        100.00
Rear castings for the frame                                 30.00
Neck for the frame (Willie made)                              40.00
Goodyear tires - 2 (EBAY)                                 110.00
Rear rim                              30.00
Rear axle                                      10.00
NOS Bottle (EBAY)                                     50.00
NOS and fuel Solenoids                        125.00
Fuel Pump with filter                        118.00
Turbo - IHI   (Gift from a friend)                                     0
Buell Blast Parts book                          30.00
Oil Line fittings-Gas-Oil tank caps                                31.00
Rear Tire - 150x80x16 - Roadrider V rated                              95.00
NOS Fogger (EBAY)                         22.00
Material for gas and oil tank                                    30.00
Ignition module and pick up - Donor                                      0
Lanyard - local auto parts                                   13.00
Front rim - Yamaha Seca (EBAY)                               110.00
Throttle (EBAY)                             10.00
Heim Joints - 4x5/8 sidecar mount                                 36.00
Sidecar wheel Yamaha Seca (EBAY)                                 90.00
Heim Joints for shifter - Kragens                                 18.00
Relay - Donor                                   0
Front End - Donor                                              0
Front axle - Donor                                   0
Rear brake caliper Ducati                                    85.00
Regulator - Donor                                   0
Clutch Cable - Donor                                0
Coil - Donor                                   0
Sidecar wheel bearings                           13.00
Material for chain guard - misc. brackets                              28.00
Sidecar axle and nut                            6.00
Nuts-bolts-washers                          10.00
Material for sidecar frame                                     38.00
Ignition switch                             12.00
Nitrous arming switch                          12.00
Transmission Sprockets - 19-20-21-tooth                              90.00
Rear wheel sprocket                          40.00
Shift light                                      149.00
Speedometer and drive (EBAY)                        50.00
Oil and Fuel lines and clamps                                     30.00
Paint                                100.00
Wiring                                  20.00
Rear chain - Master link - Half link                                   60.00
Fire Sleeve                               30.00
Nitrous fittings and lines                           160.00
More nitrous fittings and lines                         75.00
Rings and gaskets                               70.00
Fuel filter (2)                               32.00
Shorten speedo cable                            20.00
New battery                                60.00
Aluminum for platform and wheel cover - Donor                                               0
Mount and balance wheels - Donor                                        0
Upholstery                               10.00
3 Quarts of oil                               15.00
Fill the nitrous bottle                            20.00
Numbers and letters                              5.00
Brake fluid                                 5.00
Total                                2943.00
Note: Used a head a cylinder and a piston off of one of Willie’s extra motors. He will have to replace these parts at a cost of somewhere at about $300.00.
Total                                3243.00
In all fairness there are some parts that we used that we had in the shop. Such as spark plug wires, clutch cable, clutch lever, hand grips. Stock pull-off parts off of customers bikes.
The cost of the build........                                     3243.00
The cost of riding school..........                          225.00
The smile on Sheri’s face........ :-D                         priceless
« Last Edit: May 04, 2008, 01:43:28 AM by willieworld »
Offline Bob Ellis
« Reply #162 on: May 04, 2008, 04:59:00 AM »
Hi , 1st post from me on your Forum. love the quote from V8 Pinto.That says it all!!How about ya bring you're "Wheel on a stick" down here to lake Gairdner! I'm a car guy , but still love 2 (&3) wheelers on the salt.I'm sure that Jon could tell you about us,if he remembers the Vegemite!!Cheers, Bob. # 66 C/GCC.
Wanna go fast??  Come to Lake Gairdner! (It's Down Under!!)
Offline willieworld
« Reply #163 on: May 04, 2008, 03:10:05 PM »
Thanks Bob..
This is part of what makes the build worth while. Other people appreciating hard work and telling you about it.
« Reply #164 on: May 04, 2008, 03:14:25 PM »
............. Other people appreciating hard work and telling you about it.........
Hard work  :? and here I thought you were having fun  8-).  It looks great, I wish I could put the hours in that you do.  I have them, just waste them.
I see the turbo in the build expenses, but not on the bike.  What are the plans there?
c ya,
